Limited Access
- Limited Access
Limited Access
26-01-2011 8:54 AM
Last week, I "initiated" my missus new laptop, to the wireless router, and it connects every time she boots up... My laptop, used to do the same. hers is usually in the front room and mine is in the bedroom.... (about 3 feet [1metre] from the router)....
often, my laptop connects when I boot up, but quite often, in the morning, or after a long period switched off during the day, it only gets "limited access", and I have to re-boot the router before I can get a full internet connection...
as far as I can tell, her new laptop does not have any problems with connecting..
any ideas, Please?
any ideas, Please?
Message 1 of 8
(2,922 Views)
7 REPLIES 7
Re: Limited Access
26-01-2011 10:32 AM
Is your laptop running Vista by any chance?
Call me 'w23'
Message 2 of 8
(562 Views)
Re: Limited Access
26-01-2011 11:35 AM
Sorry,.... Yes... I am on VIsta Home premium.... and she is on W7...
Both Dell machines, (18 months between them so different models)
and Thomson TG858 v8 router. (wireless)
Message 3 of 8
(562 Views)
Re: Limited Access
26-01-2011 12:47 PM
From other threads three things to try, I think any of them would solve the problem but have yet to try the first two:
1) Upgrade the firmware on the router to 8.2.7.8 - http://community.plus.net/library/hardware/how-to-upgradedowngrade-the-firmware-on-the-thomson-585v7...
2) Registry change on Vista machine- http://support.microsoft.com/kb/928233/en-us
3) Make a change to the wireless settings on the router such as SSID
Cheers
Paul
Cheers
Paul
Message 4 of 8
(562 Views)
Re: Limited Access
26-01-2011 1:03 PM
as its an long time used Router and laptop not likely to be any of those
is there a wall in between you and the router, and was it there before, i.e. have you been booted into a different room?
Message 5 of 8
(562 Views)
Re: Limited Access
26-01-2011 8:10 PM
Well, I bit the bullet, and did the "firmware" update.... seemed to work ok, after I unplugged the cable, on wireless... did a re-boot of the laptop, and it could not find the router (even though it was only a couple of feet away)... ... so back in with the cable, and into the router pages.... re-named the network, (it went back to default PlusNet name) and then did the password etc.... re-booted the laptop, and no network could be found... tried several different ways to resolve it using the diagnostics.... (missus laptop on W7, in front room, found the network after re-naming back to my original name) got really frustrated , even booted into Linux Mint 9 , to see if it could find it....but nothing.... even < inSSIDer > could not find ANY wireless networks, (and normally there are about 6 or 7 locally)... so instead of doing a "proper" power down and re-boot,. .... I just pressed the ON/Off button and shut down the laptop.... On re-booting, got the usual "windows did not shut down properly" options, with "start windows normally"... and it did.... Found the router, connected wirelessly , and everything seems to be working ok ... however.... we shall have to see what happens in the morning, when the laptop has had a good nights sleep !..
Message 6 of 8
(562 Views)
Re: Limited Access
26-01-2011 8:24 PM
SWMBO XP netbook keeps on doing that, dont know why, but, right click on the WiFi icon on status bar and repair cures it til the next time
Message 7 of 8
(562 Views)
Re: Limited Access
27-01-2011 6:07 PM
Update......
24 hours later, and every time I boot up... I connect to the net....
so it seems the "firmware upgrade" has done the trick....
Thanks fellas!
Thanks fellas!
Message 8 of 8
(562 Views)
