Limited Access
- Re: Limited Access
Limited Access
11-12-2013 5:05 PM
My Broadband connection is pretty good apart from the odd drop in connection sometimes but connects back on line quickly,but this evening the little circle was going round on the logo on the taskbar and when I clicked on it I was told that I had limited access and then I was disconected for a few mins this is the first time this has happened is there a reason for this.
Message 1 of 2
(421 Views)
1 REPLY 1
Re: Limited Access
11-12-2013 5:09 PM
Seen that a few times, on both my own PCs and my wife's laptop. If it's wireless, just disable the wireless connection and then re-enable it and that should sort things. If it's a network cable, just unplugging it then plugging it back in should help.
Message 2 of 2
(215 Views)
