Lights on router
robert1935
Lights on router
When I switched my PC off on a night one of the green lights on my router switched off (The router is on 24/7) and when I switched the PC on in the morning it came back on, it was the Ethernet connection light, now when I switch the PC off ALL the green lights remain lit.
The only reason I mention this is because my usage has gone up suddenly  from 2/3gb to over over 6.87gb with most of the increase due to streaming, something I very rarely do, is  there any correlation between the two ?
I was also wondering is there a cap on usage?
Regards Bob
Fixes: 21
Re: Lights on router
Hello Bob. Now from what I remember of some of your previous posts (and connection problems) you have a Smart TV which you use - iPlayer etc I guess - that is Streaming. It only requires an hour or so of HD TV to use 2-3Gb.
As for the lights, if any other device is connected, certainly via ethernet, and that device is still on/in standy then the light will remain lit. But also check nothing is connected via Wireless and that your Wireless connection is secure and secured by a password that isn't a dictionary word.
As for limiting usage, try Manage my usage (login required).
Fixes: 162
Quote from: robert1935
Just to confirm, no there is no cap on usage for the account you're on.
 Chris Parr
 Plusnet Staff
tooslow
Regards Bob
At least you got lights on your router.....oh how I wish for activation!  Tongue
