Light off?
- Re: Light off?
Light off?
05-10-2012 1:53 PM
Hi was playing online and i was disconnected my PSN signed out so i looked at router and seen the internet light off this has never happened before in my 8 months at PN. should i worry or is this a one off thing? ( internet light quickly came back after aprox 10sec)
Message 1 of 8
(1,180 Views)
7 REPLIES 7
Re: Light off?
05-10-2012 1:56 PM
Can see that you disconnected and reconnected immediately today.
Kelly Dorset
Ex-Broadband Service Manager
Message 2 of 8
(561 Views)
Re: Light off?
16-10-2012 1:05 PM
Got disconnected again just 10 minutes ago, Cannot recall it happening since i posted this topic although i haven't been on that much this weekend. Can someone take a look at my line or something thanks
Message 3 of 8
(561 Views)
Re: Light off?
16-10-2012 2:21 PM
I can see the one form 10 minutes ago.
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13503934705696.png" />
It looks like the one from today was a profile update after a change in sync speed.
There's no errors on your line, when the connection drops, do you know if there is any noise/interference on your phone line?
Message 4 of 8
(561 Views)
Re: Light off?
16-10-2012 2:30 PM
Nope no noise etc, Line sounds very clear
Message 5 of 8
(561 Views)
Re: Light off?
16-10-2012 2:36 PM
It certainly doesn't look like there is any issues on your line at present and nothing to be concerned about, but obviously this is going to be frustrating if your gaming and it happens.
Do you know if the disconnections only happen when your gaming?
Message 6 of 8
(561 Views)
Re: Light off?
16-10-2012 3:08 PM
I've only been disconnected twice by this problem, i only play FIFA 13, ( I've played about 150 games so far ) I'm not to worried about this.
It is frustrating though when you're winning & suddenly you're disconnected from Ea server & PSN
Message 7 of 8
(561 Views)
Re: Light off?
16-10-2012 4:03 PM
Certainly frustrating! Only happens when your winning too
It looks like just a blip but it could be that something is causing interference, the best thing to do is keep an eye and see if any patterns emerge.
Message 8 of 8
(561 Views)
