Light flashing on modem
thomasjc1
Its probably just me being dumb cause i have never noticed it before i have the bt eci modem do you have an orange light that flashes on the wan port? i have a green static light and a flashing orange light on the back
1 REPLY
Re: Light flashing on modem
Hi thomasjc1,
Seems like the colours are fine and the flashing it usually data transferring, I presume you mean the LAN port?
