Light flashing on modem
- Light flashing on modem
28-03-2013 1:44 PM
Its probably just me being dumb cause i have never noticed it before i have the bt eci modem do you have an orange light that flashes on the wan port? i have a green static light and a flashing orange light on the back
Message 1 of 2
(609 Views)
1 REPLY 1
Re: Light flashing on modem
28-03-2013 4:14 PM
Hi thomasjc1,
Seems like the colours are fine and the flashing it usually data transferring, I presume you mean the LAN port?
Message 2 of 2
(324 Views)
