Level 1 speed restricted too much
- Level 1 speed restricted too much
01-02-2008 6:13 PM
Could someone please have a look at my restriction?
Premiere 2:
I have gone over 20GB and it currently stands at less than 24GB yet my speed appears to be restricted to 1Mbps. I did several tests during peak time yesterday and again this evening with various speed testers all with the same result.
At the same time I am having trouble accessing the Portal getting time out errors or pages not loading at all. All other internet access seems ok (apart from the above excessive speed restriction).
Cheers
Edit : Portal seems better now; slkow to start but pages do download
Forum Moderator and Customer
Re: Level 1 speed restricted too much
01-02-2008 6:19 PM
01-02-2008 6:21 PM
Level 1 should limit you to 2Mbs but remember, its still upto 2Mbs depending on bandwidth availability.
01-02-2008 6:23 PM
Quote from: Peter its still upto 2Mbs depending on bandwidth availability.
Yes, I realise that, but I would expect it to go over the 1Mbps mark occasionally, even more than occasionally, but it never appears to. That's why I wondered whether something has happened to the restiction level applied in this case.
01-02-2008 6:46 PM
We did have a brief problem with the portal just after 6 which has since been resolved. As for the slowdowns, I'm not sure why you're restricted to 1mb though will happily pass a ticket to the networks team to investigate this for you.
Hope that helps,
01-02-2008 7:24 PM
01-02-2008 8:04 PM
This is an up to 2mb service as advised and may run slower depending on the network speeds.
