Leaving router on to improve speed?
- Leaving router on to improve speed?
Re: Leaving router on to improve speed?
17-11-2009 4:55 PM
Oh well can't do much else Anotherone but keep my fingers crossed it isn't the router, I guess it is always advisable to have another basic router around just in case something like this happens. Do you know if PC World have D-Link gear only last time I looked it was Netgear Linksys and Belkin etc, couldn't see D-Link. I have seen advertised elsewhere the D-Link DSL-2740R which seems to be ok in the reviews. Not likely to use wireless side of things as I prefer ethernet cable.
Thanks again Anotherone
Tom
Re:Leaving router on to improve speed?
17-11-2009 9:16 PM
Hopefully the engineer will sort things tomorrow.
If you want a router for a spare you can usually pick one up from Amazon/ebay/ebuyer around the £10 mark.
17-11-2009 10:02 PM
Frustrating this speed loss thing, wish it was something really obvious but it's not, bit like have a car and its engine is only firing on one cylinder, you don't get very far.
I don't work with any kind of computer/electronic equipment, I work for myself as Plasterer/Decorator, so you can see not much call for knowledge of Sync speeds and DLMs etc.. I pick up things as I go along, might take a bit of time to get my head around the idea of some things but I get there in the end, know my way around a PC fairly well now, but never really looked into things that are linked to how you get the internet down the cables
I shall have a look around on Amazon and ebay etc.. see what turns up regarding a standby router.
19-11-2009 3:10 PM
BT engineer due later today between 1pm and 6pm, hopefully they will finally sort it out their end.
19-11-2009 5:14 PM
He has requested for it to be raised now. He did all the diagnostic tests and Sync speed was measured at 1.7Mbps so shouldn't the downstream speed be around 1.2Mbps PN as my old speed was.
20-11-2009 10:23 AM
Looking at the reports we get it's now showing a profile of 1500 for your line, this matches on our side now so fingers crossed we're back to where you should be.
20-11-2009 12:33 PM
27-11-2009 10:08 PM
If I understand correctly all that was really required was a BT person to ask another BT person to fix a stuck IP profile, and that took 8 days.
Hmmm.
27-11-2009 11:16 PM
If you care to start your own thread and post some detail of your problem and some stats, I expect we can offer some help.
29-11-2009 2:03 PM
29-11-2009 2:10 PM
29-11-2009 2:20 PM
On late last night, the spike at 2340 - something switching on or off.
The one at 2348, something coming on and running for a minute or two.
Not so keen on today's SNRM level, otherwise graph OK. What's the current sync speed?
29-11-2009 2:53 PM
29-11-2009 4:02 PM
29-11-2009 8:25 PM
