Leave well alone?
- Leave well alone?
Leave well alone?
04-07-2011 4:48 PM
I'm now in my fifth day with Plusnet and my download speed is better than I had for a long time elsewhere (now about 2.4Meg). My Netgear DG834Gv4 router using RouterStats telnet indicates that I am interleaved which is fine by me. If I have a stable speed for some time is there a risk that the interleaving will automatically be turned off and if so can that be prevented. This happened once before and my connection was a lot worse. I can post router stats, test results if needed but really all I want is to maintain current settings. It ain't broke so please don't try to fix it !
Message 1 of 2
(519 Views)
1 REPLY 1
Re: Leave well alone?
04-07-2011 4:58 PM
It should stay exactly as it is, I can't see interleaving being turned off with a sync such as you're seeing there.
Glad it's working well for you, thanks!
Message 2 of 2
(253 Views)
