Latency through ipv6 tunnel
jd678
As there's no native ipv6 with plusnet, I'm running an aviya tunnel through to SIXXS.
Noticing it got a bit slow each evening, I thought I'd graph it for a while:
There's not too many enabled right now, but if I hit an ipv6 site in the evening, the navigation is a little frustrating.
I'm assuming this is network management kicking in... any chance of bumping the priority of aviya tunnels up a bit?
Re: Latency through ipv6 tunnel
Can you do a trace through the tunnel and one in the clear please when you see these slow downs?
Is that possible for you to do?
jd678
Can do - won't be in tonight when it slows down, so I've just started recording a few things every 5 minutes:
traceroute6 www.sixxs.net
traceroute www.sixxs.net
traceroute6 2a01:348:6:12b::1 (tunnel endpoint - what's being graphed above)
traceroute gblon02.sixxs.net (ipv4 endpoint of the tunnel)
Let me know if you need anything else and I'll add it in.
jd678
OK, got some from lastnight, the following were all at 00:05:
traceroute to www.m.sixxs.net (2001:838:1:1:210:dcff:fe20:7c7c) from 2a01:348:6:12b::2, 30 hops max, 16 byte packets
1  * gw-300.lon-02.gb.sixxs.net (2a01:348:6:12b::1)  2521.74 ms  2927.01 ms
2  ae0-1235.rt2.the.uk.goscomb.net (2a01:348:0:4:0:3:0:1)  3007.38 ms  3306.99 ms  4201.29 ms
3  ge-0-0-0-1368.rt1.nik.nl.goscomb.net (2a01:348::10:1:1)  4435.88 ms  4506.71 ms  4551.8 ms
4  * ams-ix2.ipv6.concepts.nl (2001:7f8:1::a501:2871:2)  2540.8 ms  2061.62 ms
5  2001:838:0:13::1 (2001:838:0:13::1)  1778.17 ms  2088.61 ms  2558.86 ms
6  2001:838:0:12::2 (2001:838:0:12::2)  2203.32 ms  2310.85 ms  2701.73 ms
7  noc.sixxs.net (2001:838:1:1:210:dcff:fe20:7c7c)  2997.8 ms  2982.38 ms  2639.79 ms
traceroute: Warning: www.sixxs.net has multiple addresses; using 193.109.122.244
traceroute to www.m.sixxs.net (193.109.122.244), 30 hops max, 40 byte packets
1  10.2.10.2 (10.2.10.2)  1.078 ms  1.049 ms  0.963 ms
2  lo0.plusnet.thn-ag1.plus.net (195.166.128.101)  33.221 ms  34.909 ms  35.163 ms
3  vl703.thn-gw1.plus.net (84.92.4.241)  33.357 ms  39.160 ms  35.335 ms
4  195.66.226.185 (195.66.226.185)  36.683 ms  35.401 ms  35.371 ms
5  te8-7.ccr01.ams03.atlas.cogentco.com (130.117.0.197)  43.778 ms  43.600 ms  41.189 ms
6  vl3490.mpd01.ams03.atlas.cogentco.com (130.117.3.106)  46.975 ms  42.207 ms  48.659 ms
7  cogent-1101.xe-0-0-0.jun1.kelvin.network.bit.nl (149.6.128.154)  42.322 ms  48.057 ms  44.011 ms
8  nlede01.sixxs.net (193.109.122.244)  45.969 ms  52.570 ms  43.139 ms
traceroute to 2a01:348:6:12b::1 (2a01:348:6:12b::1) from 2a01:348:6:12b::2, 30 hops max, 16 byte packets
1  gw-300.lon-02.gb.sixxs.net (2a01:348:6:12b::1)  2169.6 ms  2227.38 ms  2316.1 ms
traceroute to gblon02.sixxs.net (77.75.104.126), 30 hops max, 40 byte packets
1  10.2.10.2 (10.2.10.2)  1.036 ms  0.973 ms  0.950 ms
2  lo0.plusnet.thn-ag1.plus.net (195.166.128.101)  34.105 ms  38.506 ms  35.297 ms
3  vl703.thn-gw1.plus.net (84.92.4.241)  36.803 ms  36.026 ms  39.832 ms
4  ae0-461.rt0.sov.uk.goscomb.net (195.66.226.226)  34.780 ms  35.768 ms  37.849 ms
5  ae0-1624.rt2.the.uk.goscomb.net (77.75.109.161)  37.601 ms  35.388 ms  35.664 ms
6  gblon02.sixxs.net (77.75.104.126)  35.239 ms  36.579 ms  34.321 ms
Hi James.
Yip prettly high response times evident there through the tunnel.
Can I ask what port (s) you are using for the Avaya client?
If it is not a standard VPN port is it possible for you to change this?
I've looked at the Avaya support info and trying to get a handle on which port (s) it uses is not proving to be easy.
I want to ensure that our traffic management is correctly identifying the ports in use as VPN, providing they are in the standard VPN range that is Smiley
Alernatively, a Wireshark capture of the traffic might help identify its classification.
jd678
Oops, it's ayiya, not aviya... and nothing atall to do with avaya. lol
All open, so plenty of documentation:
http://www.sixxs.net/tools/ayiya/
I could get you a capture, but I should imagine the draft will be easier to interpret...
Doh. I need to learn to read properly.
Thats much more to go on. I'll get someone to take a look at this tomorrow.
