Latency issues
Demlock
Latency issues
Hi!
I'm getting consistently high latency in the game Destiny on the PS4. Sometime it checks with the server (some players are lag switching in game, and the server contact is part of the test to identify cheaters - I've even had a few players report me for my lag as they suspect I'm switching!).
My download speed (6.3Mb/s) is as expected for my local exchange. No issues with general web use and streaming videos on Netflix. I've had a local telephone engineer recently check the phone line (cheaper than opoenreach, but not cheap!), and that's all good.
Latency on speed tests are good, 22ms - 30ms.
I thought it may be a port issue. So I have tested the following:
UPnP on and off
Port forwarding on and off.
Static and Dynamic IP
Firewall disabled/enabled
PS4 in DMZ / not in DMZ
Ports forward on static IP's and DMZ.
If I test a port that looks open from outside the network (eg from canyousee me for TCP tests) then it results as closed or stealthed.
Here's a Netstat result for my PS4 currently 192.168.1.50, taken mid-game:
Proto NATed Address                      Destination Address                State
tcp  192.168.1.50:60440                  54.148.249.228:443                  ESTABLISHED
tcp  192.168.1.50:56941                  172.97.57.22:30000                  ESTABLISHED
tcp  192.168.1.50:62285                  208.185.129.194:15700              ESTABLISHED
tcp  192.168.1.50:52729                  185.34.107.14:3074                  ESTABLISHED
tcp  192.168.1.50:52381                  52.11.202.116:443                  TIME_WAIT
tcp  192.168.1.50:58302                  52.26.181.249:443                  TIME_WAIT
tcp  192.168.1.50:58393                  50.112.184.41:443                  TIME_WAIT
tcp  192.168.1.50:62486                  50.112.184.41:443                  TIME_WAIT
tcp  192.168.1.50:53701                  52.11.202.116:443                  TIME_WAIT
tcp  192.168.1.50:51477                  50.112.184.41:443                  TIME_WAIT
tcp  192.168.1.50:54285                  52.11.202.116:443                  TIME_WAIT
tcp  192.168.1.50:53680                  52.26.181.249:443                  TIME_WAIT
tcp  192.168.1.50:53341                  52.11.202.116:443                  TIME_WAIT
tcp  192.168.1.50:60094                  50.112.184.41:443                  TIME_WAIT
tcp  192.168.1.50:61843                  52.11.202.116:443                  TIME_WAIT
tcp  192.168.1.50:57277                  52.11.202.116:443                  TIME_WAIT
udp  192.168.1.50:3074                  90.19.139.173:3074                  UNREPLIED
udp  192.168.1.50:3074                  87.228.159.12:51634                UNREPLIED
udp  192.168.1.50:3074                  86.56.73.184:3074                  UNREPLIED
udp  192.168.1.50:3074                  98.117.33.74:3074                  UNREPLIED
udp  192.168.1.50:3074                  192.168.10.4:3074                  UNREPLIED
udp  192.168.1.50:3074                  74.72.43.3:3074                    UNREPLIED
udp  192.168.1.50:3074                  77.250.221.194:3074                UNREPLIED
udp  192.168.1.50:3074                  185.34.107.50:3074                  UNREPLIED
udp  192.168.1.50:3074                  192.168.178.20:3074                UNREPLIED
udp  192.168.1.50:3074                  85.94.164.200:3074                  UNREPLIED
udp  192.168.1.50:3074                  69.243.78.185:3074                  UNREPLIED
udp  192.168.1.50:3074                  71.79.173.61:3074                  UNREPLIED
udp  192.168.1.50:3074                  31.150.219.226:3074                UNREPLIED
udp  192.168.1.50:3074                  185.34.104.124:3074                UNREPLIED
udp  192.168.1.50:3074                  78.73.31.217:57966                  UNREPLIED
udp  192.168.1.50:2001                  54.93.181.177:3074                  UNREPLIED
udp  192.168.1.50:2001                  54.93.181.225:3074                  UNREPLIED
My line stats are:
ATM Statistics TX Cells RX Cells TX CRC errs RX CRC errs
                          701689 1219868                 0 0
ADSL Status Mode State Up Speed Down Speed SNR Margin Loop Att.
    G.dmt Annex A SHOWTIME 448000 8128000.  17                 9
Hardware wise, I'm using an ASUS router (clean, no Tomato or Merlin) and a DrayTek 130 modem. I don't have easy access to a PC for flash based website diagnostics though.
The only thing I can think of is IP sharing, or another layer of NAT that I can't see. I'm pretty sure ISP's don't close ports as they did 10 years ago, and UDP 3074 is a common Xbox port (which also shows bungie's early thinking for a target platform!).
Any ideas or help would be appreciated.
23 REPLIES 23
Fixes: 160
Re: Latency issues
A warm welcome to the forums.
Looks like your ADSL(1) line is synching at the top of ADSL capability, which makes the DATA speed of 6.3Mbps appear a bit slow,  Have you had a look to see if your exchange supports 21CN (ADSL2)?  See http://www.kitz.co.uk/adsl/adslchecker.php
Setting up a TBB BQM might be helpful - if you have not got a fixed IP address, you'll need to keep creating one each time the PPP session drops.  It might help identify if there is exchange congestion, which would not be surprising on a 20CN service.
Demlock
Re: Latency issues
Yeah it is a 20 CN service. Sad
Open reach have  been saying a fibre roleout will be soon, or the cabinet is ready, for a year and a bit now. Not hit my street yet. My street is still poles and wires!
I'll set up a monitor. Good plan! Smiley
Demlock
Re: Latency issues
Fixes: 160
Re: Latency issues
Thanks for the BQM plot.  This has all the hall marks of exchange congestion.  This is going to need input from PlusNET staff (CRT) to identify if there is a better VLAN on your exchange and / or esclate the performance issue to BTw.
jelv
Fixes: 10
Re: Latency issues
If you can afford it you could consider switching to Max Premium (an extra £7.83 per month). As well as faster upload (832mpbs) it also gives you higher priority on the BT network which might well alleviate the affect of the contention.
Details of Max Premium can be found at http://trials.plus.net
You could try it for a month and then cancel it if it doesn't help.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Demlock
Re: Latency issues
I like the idea of the Max premium. Happy to pay for a service as long as it delivers, and if there's no cancellation issues, then it's worth a shot. Thanks!
The monthly cost here is higher, as plus net rank it as an exchange with no competition, but I get the first 12 months free! Smiley
I'll take a look at switching to a static IP too, as it will make long term monitoring easier.
jelv
Fixes: 10
Re: Latency issues
One thing to watch out for with Max Premium: if the equipment you are connected to in the exchange is made by Marconi you might find that the ringing of an incoming phone call causes lots of errors and maybe disconnections - this only happens on Max Premium. I experienced this and it took a long time to sort out which was by getting my line connected to alternative equipment in the exchange.
Demlock
Re: Latency issues
I'll remember that one! That problem must have been a nightmare to diagnose. I don't have the phone line plugged in, as we never use it. When Max Premium is setup I'll make sure I connect it.
Fixes: 160
Re: Latency issues
Quote from: Demlock
Can you connect it now please and check out the line for noise?  Might as well ensure that there is no issue there!
jelv
Fixes: 10
Re: Latency issues
Quote from: Demlock
1. It wasn't difficult to diagnose as when I contacted Andrews and Arnold with a view to taking up their Give us a month and we'll sort your problem broadband line or your money back they knew all about it and confirmed that my exchange had some Marconi equipment. The problem was getting Plusnet to accept and act on that information! They first came back to say that all the equipment in the exchange was Marconi even though I knew from AAISP that wasn't the case.
2. The problem occurred even if there was no phone handset plugged in. In fact the engineer reproduced the issue by connecting direct on to my line in the exchange with his test equipment.
Demlock
Re: Latency issues
Quote from: Townman
Quote from: Demlock
Good point! I it checked with the engineer three weeks ago with his phone on both the master socket without the faceplate, but I didn't have a plus net phone line at that time.
We used his phone and I don't have an adaptor for my phone (its a smaller one), so I'll pick one up tomorrow and give it a double check!
Demlock
Re: Latency issues
IP address changed (not an elegant disconnection ::)) so I've updated the monitors and attached the older images:
Demlock
Re: Latency issues
I've tested the phone line and it's fine Smiley
Plus net have got back to me on the upgrade already. Hopefully it well help! Smiley
Fixes: 160
Re: Latency issues
I would still ask questions about the utilisation of the exchange's back hauls.
