Latency issues while gaming
- Latency issues while gaming
18-03-2012 9:08 PM
Nobody else is using anything internet related apart from myself, running speed tests during the lag spike moments tells me the speed is fine (on both speedtest.net and bt speedtester (results of that below))
Games I have been playing that i've had issues with:
World of Warcraft
Minecraft
League of Legends
Star Wars - The Old Republic
Dungeon Defenders
Team Fortress 2
Call of Duty 4
Call of Duty MW3
Speedtester.bt results:
Download speedachieved during the test was - 9.33 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 10.66 Mbps
Upload speed achieved during the test was - 934Kbps
Additional Information:
Upstream Rate IP profile on your line is - 832 Kbps
Any ideas as to what could be causing this issue?
Note: I'm connected by wire and the router is in the same room as the PC & Xbox.
Re: Latency issues while gaming
19-03-2012 6:45 AM
as i have no end of gaming problems with my connection with BF3 , but yet my connection is perfect all, PN tests say nowt wrong but sometimes it gets to bad to play so i just presume it must be the router dont like gamers
19-03-2012 12:52 PM
19-03-2012 2:39 PM
How frequent are the ping spikes you're seeing? Do you happen to notice what the lights on the front of the router are doing when the ping spikes up (we're seeing a few disconnections on your line and I'm wondering if they are related).
19-03-2012 2:44 PM
I too play BF3 on PC via a Plusnet connection and don't see the same issues you're referring too. When it gets too bad to play are these always at the same time of day or does it vary? Do you use torrent software at all?
19-03-2012 9:30 PM
Quote from: Chris @lewshann
These ping spikes have actually started becoming more of a peroid of time rather than 'spikes' if you get me.. like last night it happened for 4 hours (7-11PM) and today it's been unacceptable most of the day..
It shouldn't be because of peak times because before my local exchange got upgraded i never had these issues at all.
Also the disconnections you are seeing is most likely from me resetting the router, because that actually fixes the problem sometimes.
One more thing, I've been using speedtest.net a lot and I've noticed that whenever there has been issues the area inwhich i'm placed at on the map is shown is far south on the map, whereas when it's running fine my position is further north (attached photo to show that better) The green circle while the triangle inside is where it is when it's slow, and the red circle is roughly where it is when it's fine. Don't know if that actually means anything it's just something i've picked up on.
Regarding the lights on the router. The Ethernet light is blinking constantly and in sync with the Internet light. The Wireless light blinks sometimes and stays on for the most part. The Broadband and power lights are solid
20-03-2012 7:50 AM
Yes it always evenings daytime is perfect
i get this warning triangle and its impossible to play
20-03-2012 10:57 AM
With you saying that rebooting cures it, it may be the gateway you're connected to. You could try seeing which gateway you're connected to at the time, and that might help find out what's happening.
@rongtw, I notice you're using the original router we sent you, which has the old firmware. This was known to have wireless issues, so wondering if that isn't helping. What happened to the other ones we sent you?
Jojo
20-03-2012 1:05 PM
20-03-2012 1:53 PM
Quote from: Joanne Hi lewshann,
Jojo
Just checked that link you posted, heres what I got:
You are currently connected to the gateway known as ptw-ag01.
This is located in Telehouse West.
20-03-2012 2:42 PM
20-03-2012 3:56 PM
20-03-2012 4:10 PM
20-03-2012 5:16 PM
