Latency issues when gaming on PS5
FatboyTim
Hello,
My son keeps getting kicked from online games due to High Latency issues.
The PS5 is connected via wi-fi to a TP-Link Archer VR600 modem router, via ADSL to Plusnet.
The ping regularly climbs above 1000ms, resulting in awful rubber-banding issues and subsequent auto-kicks from game servers.
I have carried out a traceroute which seems to point to some high numbers.  Please see the results below:
Tracing route to uk.www.bbc.co.uk.pri.bbc.co.uk [212.58.237.252]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms ARCHER_VR600 [192.168.1.1]
2 7 ms 7 ms 7 ms 172.16.14.167
3 * * * Request timed out.
4 9 ms 10 ms 14 ms 132.hiper04.sheff.dial.plus.net.uk [195.166.143.132]
5 16 ms 23 ms 14 ms peer7-et-4-0-4.telehouse.ukcore.bt.net [194.72.16.128]
6 238 ms 351 ms 363 ms 109.159.253.15
7 327 ms 95 ms 10 ms 132.185.254.166
8 13 ms 10 ms 10 ms 132.185.254.1
9 10 ms 10 ms 10 ms ae0.er01.telhc.bbc.co.uk [132.185.254.109]
10 13 ms 15 ms 13 ms 132.185.255.148
11 10 ms 10 ms 10 ms 212.58.238.5
12 10 ms 9 ms 9 ms 212.58.237.252
Trace complete.
I would appreciate any advice that you can give, to rectify this issue.
Kind regards.
1 REPLY 1
bobpullen
Fixes: 327
Re: Latency issues when gaming on PS5
That traceroute is perfectly fine.
The final hop (which is all that matters really) is sub 10ms: -
In fact, on an ADSL line, you're extremely fortunate to be geting response times like that.
Unfortunately though, your upload on ADSL will be little more than ~1mbps at best, meaning if anything on your network is trying to use any of that upload bandwidth, then gaming is likely to suffer.
Are you in an area that can get fibre? If so, I'd strongly suggest looking at upgrading.
Edit: To add - if you're serious about gaming and sensitive to latency then you should really look at wiring the PlayStation directly to the hub rather than relying on Wi-Fi; Wi-Fi is plagued with environmental factors that can affect the quality of the connection.
