Latency increase
- Latency increase
Latency increase
27-09-2013 7:21 PM
Does anyone have any idea why my average latency, would jump from 16ms to 25ms after changing to a static ip?
Is this just a coincidence? I tried changing gateway a couple of times with no effect
Message 1 of 4
(746 Views)
3 REPLIES 3
Re: Latency increase
27-09-2013 7:43 PM
9ms was the difference between Interleaved and fastpath (non-interleaved) on my connection.
Perhaps the interleave state changed when you restarted your connection to activate the static address.
Does your modem status tell you whether it is interleaved ?
Message 2 of 4
(372 Views)
27-09-2013 10:47 PM
Thanks for the reply Purleigh,
I have the ECI modem connected to a TP-Link WDR3600 router, so without a hardware hack on the ECI, Im unable to pull any useful stats.
If interleaved is the case, hopefully someone can put it back fastpath.
Message 3 of 4
(372 Views)
30-09-2013 10:35 AM
We don't at the moment have the option to change the interleaving mode. It is a case of leaving your line stable and see if the DLM feels the need to remove interleaving.
Message 4 of 4
(372 Views)
