Latency enquiry
- Re: Latency enquiry
Latency enquiry
13-08-2013 10:40 PM
After having the drop wire replaced I have a very stable connection.
However the ping has gone up from around 40 to over 50 would turning off interleaving improve this (if its on) or is there anything I could done to improve this
Mark
Mark
Message 1 of 3
(650 Views)
2 REPLIES 2
Re: Latency enquiry
13-08-2013 10:43 PM
If you have interleaving enabled, it will have increased your latency. If you were having line problems which have been fixed by the drop wire replacement, it is likely you'll have interleaving applied and it would be worth removing it to see how stable your line is now for it.
One of the Digi Care guys can have a look tomorrow!
Kelly Dorset
Ex-Broadband Service Manager
Message 2 of 3
(267 Views)
Re: Latency enquiry
14-08-2013 11:17 AM
Hi sparkalfa,
Just placed an order to remove it for you, I noticed you also had a capped upstream so have requested that's uncapped for you as well. It'll complete tomorrow morning for you, hope it improves things
Message 3 of 3
(267 Views)
