Latency doubled over night
- Latency doubled over night
22-05-2013 7:37 PM
Pinging bbc.co.uk [212.58.253.67] with 32 bytes of data:
Reply from 212.58.253.67: bytes=32 time=19ms TTL=120
Reply from 212.58.253.67: bytes=32 time=18ms TTL=120
Ping statistics for 212.58.253.67:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 18ms, Maximum = 19ms, Average = 18ms
Re: Latency doubled over night
22-05-2013 7:44 PM
22-05-2013 7:49 PM
Strange how yours has gone up though?
22-05-2013 7:50 PM
22-05-2013 7:53 PM
I'd say you've had interleaving applied to your line overnight. 4-5am seems to be the most common time for the DLM to make changes.
If your line remains stable and error-free enough for the next 3-4 weeks then you may find the DLM removes interleaving.
Alex
22-05-2013 8:21 PM
Quote from: 30FTTC06 I didn't say it was Hi, i said it had doubled over night njay.
I never said you did
22-05-2013 9:15 PM
22-05-2013 9:19 PM
23-05-2013 6:57 AM
Quote I wish it was that simple tijara33
Unfortunately that exhausts my knowledge banks. Good luck.
23-05-2013 12:25 PM
Interleaving is currently on your line, at the lowest level possible. This would explain your increase though.
23-05-2013 10:48 PM
