Latency Spikes on the home network
- Latency Spikes on the home network
23-04-2020 9:46 AM
I'm experiencing latency spikes on my broadband connection. When ping something on the internet (8.8.8.8), every minute or so a packet would take around 500ms to return. I thought it might be a problem on the internet but then tested it with a ping to the home router 192.168.1.254 and got the same. Wifi or Ethernet, same result.
If I reboot the router the problem goes away but then next time I go to play online games (so the next evening) its back and requires another reboot. Obviously I don't want to have to reboot my router every day.
The router is a Hub One with firmware '4.7.5.1.83.8.263' Is this the most recent?
It is possible that another device is causing this but I feel like the router should be able to handle this which is why I'm thinking it is either faulty or has a bug in the firmware.
Re: Latency Spikes on the home network
23-04-2020 10:44 AM
xxx.263 is the latest firmware.
Yes it has bugs. You can read through the router board to get a view of these.
