Latency Graph
greshoff
Latency Graph
Could someone have a look at this ping graph and let me know if there is anything that needs to be done to reduce the spikes or does it look OK?. Thanks
29 REPLIES 29
gary42
Re: Latency Graph
Are you using your broadband during these 'spikey' periods? In particular what was happening around midnight?
On a Plusnet connection I wouldn't expect to see high latency spikes caused by downloads due to their QOS but this kind of graph could correspond with high upstream utilisation.
To solve that you would need to add your own upstream QOS into the mix.
Is it FTTC or ADSL?
greshoff
Re: Latency Graph
I am on ADSL, I was asleep at midnight and as far as I am aware the internet was not being used
Gus
Re: Latency Graph
http://www.thinkbroadband.com/faq/sections/bqm.html
You leave a pc active and something was active you don't know about
Someone in your house is online without you knowing it
Someone is leeching off your un-secure wifi
FTTP 500 regrade from Tues 28th November
greshoff
Re: Latency Graph
My wifi is secured. All PC's were switched off. My daughter said she used her phone briefly
Gus
Re: Latency Graph
Your graph points to some thing using your connection.  I would disable wifi and make sure all pcs/laptops are off for one night and see what happens
KevinA
Re: Latency Graph
This could be a wifi mobile device uploading photo or video.. this seems more intensive on the upload since the latest smart phones record in HD and create larger files and is most noticable on ADSL connections.
greshoff
Re: Latency Graph
When reading these ping graphs, What exactly should I be looking for. I assume dropped packets are bad but what else?
gary42
Re: Latency Graph
Have a read of this:
Also for dropped packets you are correct. Have a read of this:
http://revk.www.me.uk/2014/02/what-is-packet-loss.html
The yellow spikes aren't too much to worry about although a bit odd if you think nothing is using the connection.
The high yellow line can be caused by just one ping out of 100 in that time period being high as it is plotting the maximum. E.g. 99 at 10ms and 1 at 200ms.
Blue is the average response over 100 pings (One per second).
If this starts creeping up you are more likely to notice it while using your connection for latency sensitive things like gaming.
My bet is still on uploads for those big blue spikes. As Kevin says it could be something like an Ipad/phone backing up to icloud.
It's surprising what smart phones/tablets can get up to when you are not watching  Smiley
Have you had your upstream uncapped by Plusnet?
When capped the upstream bandwidth is barely enough to cope with the ack packets from a 24 Mbps connection download.
greshoff
Re: Latency Graph
Thanks for the post it was helpful.
Here is my graph for today.
I have been uploading some big files to cloud storage over past couple of hours. Also first thing this morning. Not sure about all the red - dropped packets
Yes upload has been uncapped
goldenfibre
Seasoned Pro
Fixes: 12
Re: Latency Graph
greshoff is that fibre or just standard broadband? That's look awful - which gateway is it?
greshoff
Re: Latency Graph
It is not fibre, ADSL2 . What do you suggest I can do to improve things. Not sure about gateway, how do I find this out?
goldenfibre
Seasoned Pro
Fixes: 12
Re: Latency Graph
http://usertools.plus.net/@gateway/ it will tell you which gateway are u on it
greshoff
Re: Latency Graph
Thanks for that. It says I am on -  pcl-ag07
goldenfibre
Seasoned Pro
Fixes: 12
Re: Latency Graph
No problem. More information of gateway here: http://community.plus.net/forum/index.php/topic,123979.0.html
