Large decrease in speed
- Re: Large decrease in speed
02-04-2009 5:01 PM
Your DSL connection rate: 4768 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 1500 kbps
Actual IP throughput achieved during the test was - 1276 kbps
And here are my stats:
ADSL Link Downstream Upstream
Connection Speed 4768 kbps 448 kbps
Line Attenuation 40 db 10.5 db
Noise Margin 9 db 16 db
Is this simply a case of waiting for my ip profile to get updated? Or is something else wrong. Thanks in advance.
02-04-2009 5:04 PM
However more serious is why it dropped in the first place.
If you didn't do something like plugging an unfiltered device in then a bit of detective work is in order.
If you raise a ticket asking for the reported sync changes over the past week then this should tell you when it happened and may just give you a pointer for identifying the cause
02-04-2009 8:10 PM
03-04-2009 10:00 AM
Final question! Some time last year I requested maxdsl and was told that my line wouldn't support anymore then I was currently getting (around 3.5mbps), is this still the case? And if I was getting 3.5mbps anyway wouldn't this suggest that I was already on maxdsl instead of the fixed 2meg line? Sorry if any of those questions are obvious, but they've been niggling me for a while now.
03-04-2009 10:04 AM
Can you advise the model of router you have and also is it possible to connect the router and phone to the test socket so that your internal wiring is ruled out.
03-04-2009 10:12 AM
Unfortunately I'm at work at the moment, so I can't do any tests but I have a Netgear DG834 v3 with latest firmware. I can't use the test socket as I don't have one on the old style master sockets.
03-04-2009 10:17 AM
Is there only one telephone point in the property or are there others hard wired in.
To allow fault and problem tracking I suggest downloading Routerstats http://www.vwlowen.co.uk/internet/files.htm and running it.
This will allow tracking of noise margin, sync rates etc. over time
03-04-2009 10:29 AM
03-04-2009 10:33 AM
03-04-2009 12:01 PM
Don't tamper with ANY wiring at the moment. The chances are you have a line fault and as such you should be able to get your old Master socket replaced F.O.C. with a new Master LIneBox as part of the repair. Have a listen to your phone line, do you hear / have you heard any crackling or other intermittent noises on the line?
That said it could still be a filter (or router) gone faulty. You will need to be very methodical and use a process of elimination to pinpoint the problem. If you need some further guidance, I could post some later.
Meanwhile getting RouterStats running as Jim has suggested and a set of current line stats would help. With the RouterStats setup I would suggest you set the plotting to sample every 8 seconds, 900 points per page & Ramp Mode (all should become clear when you look at it, if not, Jim is an expert so I'm sure he'll point you the right way.).
04-04-2009 11:51 AM
Some good news! Flying in the face of logic I decided to remove my bell wire (I didn't cut it off just in case i need to put it back) and am now getting:
Your DSL connection rate: 5216 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 3000 kbps
Actual IP throughput achieved during the test was - 2654 kbps
With stats:
Connection Speed 5216 kbps 448 kbps
Line Attenuation 41 db 10.5 db
Noise Margin 11 db 16 db
I've had routerstats running overnight and I haven't dropped connection, so is there much point me posting the graph? I did notice that the noise margin gets lower at night, is this normal? Thanks again.
Edit: @Anotherone, yes there is some noise on the line, but I'm not sure how loud qualifies. It's audible but doesn't really impede conversations and I'm a bit hesitant to get BT out in case they try and stick me with a huge bill. After a bit of testing I've noticed that one phone seems to be more susceptible to the noise (BT phone ironically enough) and that it actually seems to increase the noise on the line somewhat.
04-04-2009 12:27 PM
Regarding the phone which gives the greater noise problem - is this a DECT phone or a hard wired phone
04-04-2009 12:58 PM
04-04-2009 1:27 PM
04-04-2009 2:29 PM
