Lack of internal communication.
glloyd
I reported a fault with my BB dropping and on the 20th I received an email to say Interleaving has been turned on. This cured the problem. Today, five days later, I get a phone call to say they were going to increase my SNR to 9 to solve the problem. I said I did not want it changed and was told the order would be cancelled. I then get an email to say it would take 48 to 72 to put it back to 6db. It had already been changed this morning. Talk about the right hand not knowing what the left is doing.
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Lack of internal communication.
Sorry for the confusion on the support ticket. Looking at the line it's still showing a 9db target which appears to have increased to that automatically. I'm trying to set this back to 6 but at the moment I'm unable to. I'll keep a note of your account, move the ticket to myself and try again later this afternoon.
 Chris Parr
 Plusnet Staff
glloyd
Thanks Chris. The chap that phoned me this morning said HE had changed it to 9db this morning.
Plusnet Staff
Plusnet Staff
Fixes: 159
That'll explain why I can't change it back yet, I believe it only allows 1 change like that in 24 hours. I couldn't find his order so thought it was automated. I'll get the order to move you back placed tomorrow morning as soon as I can.
 Chris Parr
 Plusnet Staff
glloyd
Thank you Chris all done now.
Plusnet Staff
Plusnet Staff
Fixes: 159
Thanks for letting me know.
 Chris Parr
 Plusnet Staff
Fixes: 142
Moderator's note by Mike (Mav): I have changed the fix to Chris as per message #4.
Forum Moderator and Customer
