LINKSYS E2500 - Will this work with FTTC?
Cutterschoice
Hey guys, i'm after some help, the router i got supplied by plusnet is giving me some headaches with wireless and random cut outs.
Will this one work with fibre?
http://www.linksys.com/en-apac/products/routers/E2500
Thank you for any help.
Fixes: 153
Re: LINKSYS E2500 - Will this work with FTTC?
It will do, any particular reason you're looking at that one?
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Cutterschoice
Not really, it's within budget which is around £50, we use a lot of Linksys stuff in work, which also seems to be reliable, other than that nothing.
I’m not worried about looks etc., just more reliable wireless signal, I live in a flat so range isn't really an issue, and I’m no further than 10m away from it.
