LCP up and down with CHAP authentication success, basically line disconnects, why?
- Re: LCP up and down with CHAP authentication succe...
09-08-2018 9:38 AM - edited 09-08-2018 9:42 AM
I seem to be getting a lot of these short term line disconnections, anyone have any clues as to what is going on:
This is the log from my router.
Wed, 2018-08-08 12:58:33 - LCP down.
Wed, 2018-08-08 12:58:54 - Initialize LCP.
Wed, 2018-08-08 12:58:54 - LCP is allowed to come up.
Wed, 2018-08-08 12:58:54 - CHAP authentication success
Wed, 2018-08-08 21:08:54 - LCP down.
Wed, 2018-08-08 21:09:07 - Initialize LCP.
Wed, 2018-08-08 21:09:07 - LCP is allowed to come up.
Wed, 2018-08-08 21:09:08 - CHAP authentication success
Other than this my line works just fine, recent new ADSL filter, done the Quiet Line Test and it's very quiet line indeed, my speeds are very good (router stats) and the Plusnet broadband speed tester, even had a new line from house to pole and recent work at village junction box by Open Reach to fix a problem about 2 years back.
Router stays on 24/7
Any clues?
Re: LCP up and down with CHAP authentication success, basically line disconnects, why?
09-08-2018 4:18 PM - edited 09-08-2018 4:20 PM
Hi @EdwardVIII,
I'm sorry to hear that you are experiencing drops in your connection. I've tested your line and the test isn't picking up the cause of this issue, however I can see the drops on your connection log.
For reference, today's test result is as follows:
xDSL Status Check | |||
Circuit ID: | CBUK71003586 | Service ID: | BBEUXXXXXXX |
Telephone NO.: | NA | Test Executed On: | 09-08-2018 16:05:34 |
xDSL Status Test Summary | |||||
Sync Status: | Circuit In Sync | ||||
General Information | |||||
NTE Status: | NTE Power Status: | PowerOn | Bypass Status: |
Upstream DSL Link Information | Downstream DSL Link Information | |
Loop Loss: | 37.8 | 63.5 |
SNR Margin: | 7.0 | 6.0 |
Errored Seconds: | 0 | 20 |
HEC Errors: | 0 | |
Cell Count: | 6042 | 8586 |
Speed: | 556 | 2267 |
Maximum Stable Rate (KBPS): | 1728 | Fault Threshold Rate (KBPS): | 1382 | ||
Mean Time Between Retrains (Seconds): | 16510 | Mean Time Between Errors Upstream (Seconds): | 526 | ||
Indicative Line Quality: | A | Mean Time Between Errors Downstream (Seconds): | 6 | ||
Custom Thresholds | |||||
MTBR_RED: | MTBE_RED: | ||||
MTBR_GREEN: | MTBE_GREEN: |
and your connection log is as follows:
Thank you for trying those checks from your side, including the quiet line test. Please can you run through our troubleshooting guides here just to make sure that you've not missed any of the checks on your side. If these troubleshooting checks don't resolve the problem, please report the issue here and let us know when you've completed it - we'll then be able to investigate this further for you.
10-08-2018 6:16 AM
Thanks for the info, indeed that record does seem to tally with my disconnections. I'll do some tests and see how it goes, I'm currently connected directly into the phone line test socket with my router.
