LCP is down
- LCP is down
LCP is down
30-09-2009 1:00 PM
hi guys
I have had ongoing speed issues since going on 21cn which is probably down to BTs dlm however i have just noticed on my netgear 834g router reporting LCP is down a couple of times a week
What does this mean, can i do anything about it, will it affect the dlm. Is there any other info on this issue
Message 1 of 4
(937 Views)
3 REPLIES 3
Re: LCP is down
30-09-2009 1:46 PM
LCP is Link Control Protocol. It means that your router dropped sync with the exchange.
It's possible that that may have resulted in the DLM assigning a higher noise margin or a banded profile, but we won't know until that happens.
Message 2 of 4
(372 Views)
Re: LCP is down
30-09-2009 6:33 PM
james i belive lcp down has nothing to do with your sync to the exchange. when the BT's radius servers play up on 21cn i get lcp down but am still sync'ed on my 834g v4
Message 3 of 4
(372 Views)
Re: LCP is down
30-09-2009 11:29 PM
Not necessarily. LCP generally refers to the ADSL link.
Message 4 of 4
(372 Views)
