Kmail won't send
- Re: Kmail won't send
Kmail won't send
06-05-2009 8:13 PM
I have just set up Kmail on Linux and can't sort out the send as it comes back
Sending failed:
Sendmail exited abnormally: sendmail: Cannot open mail:25
The message will stay in the 'outbox' folder until you either fix the problem (e.g. a broken address) or remove the message from the 'outbox' folder.
The following transport was used:
Sendmail
I had setup up relay.plus.net, but that hasn't workded. Maybe I shouldn't put that. Anyone know how I can resolve it?
Tony
Sending failed:
Sendmail
Tony
Message 1 of 5
(1,364 Views)
4 REPLIES 4
06-05-2009 8:42 PM
Looks like it's not set to relay.plus.net
here are the settings http://www.plus.net/support/customer_service/using/settings.shtml
Can you post a screen shot of the settings with any personal info removed?
Message 2 of 5
(547 Views)
06-05-2009 8:43 PM
I don't know Kmail but relay.plus.net is correct for the outgoing server. The incoming one is mail.plus.net.
You shouldn't have Secure Password Authentication set, or Outgoing server requiring Authentication.
Edit: Adie's typing quicker than me tonight!
Message 3 of 5
(547 Views)
07-05-2009 1:33 AM
Quote from: TonyPhotoplus I have just set up Kmail on Linux and can't sort out the send as it comes back
Sending failed:
I suspect the use of Sendmail is your problem; Kmail doesn't require it to be able to send mail (and on a home machine Sendmail is best avoided like the
Try deleting the account you've set up and starting afresh - but don't 'Use Sendmail'
If you don't have (or didn't choose) the option to use Sendmail, try disabling it on your system altogether.
Message 4 of 5
(547 Views)
08-05-2009 5:54 PM
Thanks guys, I just gave up in the end and managed to transfer all of Thunderbird. kmail I gave up on
Tony
Tony
Message 5 of 5
(547 Views)
