Kindle
- Kindle
Kindle
10-09-2012 12:31 AM
Hi
Hope this is the correct site. I moved over to plusnet broadband a while ago. Last night I decided to move an e-book I had been reading on my pc to my kindle, forgetting that I'd not used it since the change over. It asked me to connect to plusnet which I tried to do. It asked for my pass word. I put in my password for plusnet but it said this was incorrect. What password are they asking for?
Hope someone can help
Message 1 of 4
(704 Views)
3 REPLIES 3
Re: Kindle
10-09-2012 12:51 AM
Hi! It sounds like you're looking for the wireless password for your router, rather than the plusnet broadband password. If the router was supplied by Plusnet, then the password is likely to be on a label on the underside of the router, something like the one shown here; http://www.plus.net/support/broadband/wireless_broadband/wireless_connect_win7.shtml
Message 2 of 4
(305 Views)
Re: Kindle
10-09-2012 1:04 AM
Hi Between1and 16cha,
thank you, thank you! You've saved my sanity!
It's been one of those days, you know the sort everything's fine and then crash nothing is working! Tv keeps going on and off every half hour, it's a lose connection and will get fixed tomorrow and then the kettle went! The kindle was the last straw. Going to turn the lights out and sulk for ten seconds and then read!
Dragon
Dragon
Message 3 of 4
(305 Views)
Re: Kindle
10-09-2012 1:08 AM
No problem - glad it was as simple as it seemed.
I think we all get those days!
Message 4 of 4
(305 Views)
