Kind PlusNet folk, please nudge my stuck Line Speed?
- Kind PlusNet folk, please nudge my stuck Line Spee...
- « Previous
- Next »
Re: Kind PlusNet folk, please nudge my stuck Line Speed?
11-01-2013 2:51 PM
I can see that's been picked up by the faults team, looks like they need speed test results - if you could run the initial test and second test at http://speedtest.btwholesale.com and add that to the ticket we'll be able to push it on further for you.
11-01-2013 3:27 PM
I have to say I found the ticket response very disappointing. I pointed to this thread in my report, and summarised the problem. But I don't get the impression that anyone has read this thread, nor done anything but run through a standard script. This is what I've received :-
Quote Thanks for your patience during our investigation.
I have run sufficient testing on your line and can see that all parameters look to be running correctly. I can see that the throughput based on your profiles is running correctly. I can also see that the synchronisation rate is normal for the length of your line.
Please run a speedtest at http://speedtest.btwholesale.com/ so we can use BT's back end system to diagnose further on the back of these results. Ensure the connection is with a wired connection, you will only need your telephone number for this test. If you have any further issues on the connection.
Due to the very nature of faults, we can only request that you monitor the connection for several days, in order to confirm you are satisfied this is resolved in full.
Please do not hesitate to get back in touch online at http://contactus.plus.net/ or by phone on 0345 140 0200 if we can be of further assistance.
Kind regards,
Throughput of 6.5Mb while I have a sync rate of 12.4Mb and an IP Profile of 10.92Mb is not "running correctly". That is the problem I reported. Of course monitoring the connection for several days is not going to confirm I am satisfied. Of course I need further assistance. Sheesh :(.
Matt, would someone at PlusNet please get to grips with this?
I also see this on the ticket, in case it offers any clues to anyone else. (Indeed, aren't these partially from the last BT speedtest I did?) :-
WP Profile: Generic Speed 11600 No Time Out
WBC 160K - 24M Medium delay (INP 1) 6dB Downstream, 448 Low delay (INP 0) 6dB Upstream (ADSL2+)
Our test also indicates that your line currently supports an estimated ADSL2+ broadband line speed of 7.5Mbps; typically the line speed would range between 5.5Mbps and 12Mbps
xDSL Status Test Summary
Sync Status: Circuit In Sync
General Information
NTE Status: NTE Power Status: PowerOn Bypass Status:
Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 17.1 35.5
SNR Margin: 27.5 3.3
Errored Seconds: 0 0
HEC Errors: 0
Cell Count: 2862 3286
Speed: 444 12375
Maximum Stable Rate (KBPS): 9088 Fault Threshold Rate (KBPS): 7270
Detailed Records
Attribute: DownStream-BE UpStream-BE
TAP ID: TAP-1 TAP-1
Test ID: 1357747385 1357747386
Start Date/Time: 09-01-2013 16:01:54 09-01-2013 16:02:08
Test Duration: PT12.500S PT9.406S
Domain Name: plusdsl.net plusdsl.net
Network Identifier: CBUK88042749 CBUK88042749
Service Identifier: BBEU08258341 BBEU08258341
BRAS IP Address: 10.170.162.1 10.170.162.1
VPI: 0 0
VCI: 0 0
Peering IP Address: 46.208.139.101 46.208.139.101
Infrastructure Type (C+ C++ HG/LTS): LONS LONS
System Name: EUSC Performance Tester EUSC Performance Tester
System Host: EUSC Performance Tester EUSC Performance Tester
Policy Type: BestEffort BestEffort
Policy ID: WBC WBC
Profile Rate: 10336 448
Test File Size: 9534902 56407
File Transfer Average Throughput/Session: 6540 250
14-01-2013 11:50 AM
Quote from: mplusnetuser Throughput of 6.5Mb while I have a sync rate of 12.4Mb and an IP Profile of 10.92Mb is not "running correctly". That is the problem I reported. Of course monitoring the connection for several days is not going to confirm I am satisfied. Of course I need further assistance. Sheesh :(.
Well, PlusNet now say that the problem is not that my throughput is too low, but that my sync rate is too high! :-
Quote BOT - DSL Logged Faults
9:45am, Monday 14 Jan 2013
[INTERNAL]
RADIUS: Connected for 3:19:42
4 drops in last 24 hours
7 drops in last 72 hours
3 of 19 (16%) User Req Drops in last 7 days
[EDIT: N.B. I'm in SNR retraining since 19/1: hence the drops]
WP Profile: Generic Speed 10200 No Time Out
WBC 160K - 24M Medium delay (INP 1) 3dB Downstream, 448 Low delay (INP 0) 6dB Upstream (ADSL2+)
General Information
Loop Loss: 17.0 34.5
SNR Margin: 28.0 4.3
Errored Seconds: 0 2
HEC Errors: 0
Cell Count: 4028 6042
Speed: 444 12153
Mean Time Between Retrains (Seconds): 43008 Mean Time Between Errors Upstream (Seconds): 43008
Indicative Line Quality: G Mean Time Between Errors Downstream (Seconds): 424
Test ID: 1357916483 1357916484
Start Date/Time: 11-01-2013 15:00:15 11-01-2013 15:00:30
Test Duration: PT12.406S PT9.390S
User Name:
Directory Number:
VPI: 0 0
VCI: 0 0
Peering IP Address: 87.112.145.xxx 87.112.145.xxx
Policy ID: WBC WBC
Profile Rate: 10917 448
Test File Size: 9469370 57232
File Transfer Average Throughput/Session: 6590 240
Summary: The speed line profile is over the estimate for the connection the throughput is in within limits of the connection. Sending a engineer for this issue is unlikely to achieve anything due to the speed being estimate. I am going to try reset the connection to a target snr margin 6db this is to give the line a more realistic line profile.
Your batch Id is 1-14584311056.
9:58am, Monday 14 Jan 2013
The throughput you are receiving is within limits of the connections estimated speed given to us by our suppliers for your line.
The line sync speed has been falsified by a very low snr margin target at 3db this can sometimes cause the poor throughput on the connection. I have reset the connection to a target to 6db which will give you a more realistic sync and line profile speed.
The reset takes 4-24 hours to go through the suppliers system, the line will then enter a 10 day training period to give you the best possible speed. I would like to apologise for any inconvenience caused by this issue.
Please do not hesitate to get back in touch online at http://contactus.plus.net or by phone on 0800 432 0200 or 0345 140 0200 if we can be of further assistance.
I just don't get this :(.
The target SNR was previously reduced from 4.5 to 3 by PlusNet (at my request) in an attempt to increase throughput I (mis?)understood that if the target SNR margin was too low, then the symptom would be more frequent disconnections, not lower throughput. What happened was that I got a slightly higher sync (+0.8Mb), and I didn't get more frequent disconnections and it did nothing to throughput. So I think this target SNR adjustment is a red herring.
Does anyone have any theories why there should be such a gap between throughput (6.5Mb) and sync/line speed (12+/10+Mb)?
Or, put another way, why my line with an attenuation of ~35, for which the ADSL2+ speed calculators suggest ...
http://www.coolwebhome.co.uk/calc/calculator.php
"Normal speed range at 35dB attenuation is 10500 Kbps to 13900 Kbps"
http://www.kitz.co.uk/adsl/max_speed_calc.php
"BT 21CN WBC & adsl2+: 11712 kbps ; IP Profile: 10330 kbps"
http://www.skyuser.co.uk/adsl2_checker.php
"We estimate your line is capable of between 10mb to 12mb broadband on an ADSL2+ service."
... should be limited to 6.5MB?
14-01-2013 12:13 PM
Personally if the sync speed is good anyway (say more than 8MB) I'd stick with a higher noise margin for a smoother experience than push my luck going for ultimate speed.
14-01-2013 12:39 PM
Here are a couple of router stats dumps. Both are since the target SNR was lowered. The first is before I killed the bell wire, and the second (shorter period, re retraining drops) afterwards :-
Bandwidth (Down/Up - kbit/s): 9067/444
Physical Layer Statistics:
Modem state: up
Up time (Days hh:mm:ss): 5 days, 14:05:16
xDSL Standard: ITU-T G.992.5
xDSL Annex: Annex A
Channel Mode: Interleaved
Number of reset: 1
Chipset Vendor info (G.994.1): Local Remote
Country code: B500 B500
Specific: 0000 71BE
System Vendor info (showtime): Local Remote
Country code: 0F00 0000
Specific: 3C61 0000
Bearers generic info DS US
Payload rate [Kbps]: 9067 444
Attenuation [dB]: 35.0 17.3
Margins [dB]: 3.9 26.8
Output power [dBm]: 0.0 12.8
Number of bearers: 1
Bearer 0 DS US
INP [DMT symbols]: 1.05 0.00
Delay [ms]: 7.98 1.13
Depth []: 64 0.00
R: 10 0
G.997.1 Statistics (Current):
Failures:
Line failures Near end
Loss of signal (LOS): 0
Loss of frame (LOF): 0
Loss of power (LPR): 0
Performance monitoring:
Line PM: Near end
Error second (ES): 28994
Channel PM: Near end Far end
Bearer 0:
Code Violation (CV): 2641 0
FEC: 213073271 0
ATM data path PM: Near end Far end
Bearer 0:
HEC violation count (HEC): 77636 N/A
G.997.1 Statistics (last 15 minutes):
Failures:
Line PM: Near end
Error second (ES): 0
Bearer 0:
FEC: 213073271 0
Bearer 0:
G.997.1 Statistics (last 24 hours):
Failures:
Line PM: Near end
Error second (ES): 29
Bearer 0:
FEC: 213073271 0
Bearer 0:
Up time (Days hh:mm:ss): 0 days, 5:58:24
xDSL Type: ADSL2+
Bandwidth (Down/Up - kbit/s): 12154/444
Modem state: up
xDSL Annex: Annex A
Number of reset: 1
Specific: 0000 71BE
Specific: 3C61 0000
Payload rate [Kbps]: 12154 444
Attenuation [dB]: 34.5 17.0
Margins [dB]: 4.4 27.4
Output power [dBm]: 0.0 13.0
Bearer 0 DS US
INP [DMT symbols]: 1.09 0.00
Depth []: 64 0.00
R: 14 0
Failures:
Line PM: Near end
Error second (ES): 145
Bearer 0:
Code Violation (CV): 164 0
FEC: 11906284 0
Bearer 0:
HEC violation count (HEC): 8760 N/A
Failures:
Line PM: Near end
Bearer 0:
FEC: 11906284 0
Bearer 0:
Failures:
Line PM: Near end
Bearer 0:
FEC: 11906284 0
Bearer 0:
I have no idea how to interpret all of that, so thanks to anyone with the smarts and kindness to take a look.
Do the errors look too high? Enough to cause throughput problems?
14-01-2013 2:37 PM
Without changing the target, you might want to consider doing a resync when the noise margin is at it's lowest. This will give you a bit slower sync and the target noise margin which will then rise higher when there is less background noise.
14-01-2013 3:53 PM
Margins [dB]: 4.3 27.9
Failures:
Line PM: Near end
Bearer 0:
Code Violation (CV): 219 0
FEC: 11937197 0
Bearer 0:
HEC violation count (HEC): 11891 N/A
So, if I've got the right idea, with a current SNR of 4.3, under the load of 3 BT tests, my error counts have incremented by these amounts (compared to the last stats dump earlier today) :-
Last 15 Mins Previous 6 Hours
(new stats) (posted below)
Error Seconds: 19 145
CRC Errors: 55 164
HEC Errors: 3131 8760
FEC Errors: 30913 11906284
Does that first column seem problematically high for 3 speedtests? I don't know if a noise margin of 4.3 is considered low or not (it's lower than the forthcoming target of 6.0). But if I'm getting low errors (if they are?) while it's at 4.3, during the load of repeated BT speed tests, then how is it supposed to be responsible for my low download rate (of 6.37 during the 3 tests)? Maybe, if I time it right later this evening, I might see an even lower throughput and more errors, while the SNR is lower (assuming the new target of 6 hasn't kicked in by then). But what will that establish if, right now, I'm seeing low errors, yet downloads of only ~6.5Mb?
Have I got the wrong end of the stick?
As for re-syncing at a lower rate - well, I'm in retraining, so it has already fluctuated between 13587 and 11717. Yet downloads are always 6.5Mb or less. Why so?
14-01-2013 4:11 PM
My speed test results are not that far short of my IP Profile.
It would help if someone from Plusnet could confirm that they are seeing speeds on BRAS and DSLAM which are the same as you see for the IP Profile.
14-01-2013 4:14 PM
Last 15 Mins
(new stats)
Error Seconds: 21
CRC Errors: 49
HEC Errors: 1958
FEC Errors: 13366
Which just appear confirm the same, or lower, error rates, while conducting 3 BT tests.
14-01-2013 4:24 PM
Quote from: jelv As a gauge I'm seeing just over 8,000 error seconds in a whisker under 7 days on a sync of 15900 with noise margin varying between 4 and 7.
If my maths is right, yours are about 2.5 times higher than mine, with no ill effect. I just don't think errors or SNR margins or "falsified" sync speeds have anything to do with this problem.
14-01-2013 4:28 PM
Quote from: jelv It would help if someone from Plusnet could confirm that they are seeing speeds on BRAS and DSLAM which are the same as you see for the IP Profile.
What does that mean, please? (For completeness, my IP Profile is currently 10.72 Mb and PlusNet Line Speed 10.2 Mb).
Previously, Matt said this :-
Quote from: Matt Oddly I've just run a consistency check on the line and it's come back as passed with the speeds on BRAS and DSLAM matching at 8654, so given the other discrepancies we're seeing about the only thing I can think of is an SNR reset to allow the line to retrain. Let us know if you'd like to go ahead with that mplusnetuser, and we'll set it going for you.
14-01-2013 5:24 PM
15-01-2013 3:34 PM
[...] The line sync speed has been falsified by a very low snr margin target at 3db this can sometimes cause the poor throughput on the connection. I have reset the connection to a target to 6db which will give you a more realistic sync and line profile speed.
More than 24 hours later, nothing seems to have happened. No re-sync; and I'm still seeing a margin of 3.7dB (not that I think it's a likely fix anyway).
No response at all from PlusNet, either on the fault ticket, or here. I seem to have been abandoned :(.
16-01-2013 4:12 PM
You've certainly not been abandoned. I'll be picking this issue up this evening for you and get in touch to discuss the issue.
- « Previous
- Next »
