Keep losing my broadband connection
elkieluca
Yesterday and now today about the same time 2.30 my internet light goes out and I get taken to the page where it says 'No connection' or words similar to that.  I have no idea why this is happening as everything has been ok since my last problem with the phone not working.  It doesn't stay off long but even so its not right.  Any ideas why this is happening.  Thanks.
9 REPLIES 9
MatthewWheeler
Fixes: 479
Re: Keep losing my broadband connection
Something appears to have started over the last 24 hours
Our testing isn't showing any issues on the line. I'd recommend going through our troubleshooter using the link below
https://faults.plus.net
 Matthew Wheeler
elkieluca
Ok I've done that.
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
Thanks, faults will pick this up in due course.
 Tony T
elkieluca
Thanks plusnettony. As usual you are always helpful and since your input I have heard from the techs and that it's now being looked at.
MatthewWheeler
Fixes: 479
I can see you have a engineer booked for Monday morning.
Let us know how you get on.
 Matthew Wheeler
elkieluca
Thanks Matthew I will let you know.
elkieluca
Engineer came on time and took a while to sort it but he did a good job and I now get an even faster speed than before.  So thank you Plus Net.
MatthewWheeler
Fixes: 479
Glad to hear it's sorted.
Let us know if you have any further issues.
 Matthew Wheeler
elkieluca
Ok thanks.
