Keep getting "page could not be found"
- Keep getting "page could not be found"
19-08-2007 10:50 AM
I keep getting page could bnot be found errors, and the only way to get it working again is to unplug the router, and plug it back in again, where the internet conection seems OIK for a whiile, before it all slows down again and then "page could not be found"
Message 1 of 8
(3,032 Views)
7 REPLIES 7
Re: Keep getting "page could not be found"
19-08-2007 2:15 PM
anyone got any ideas?
Message 2 of 8
(1,031 Views)
19-08-2007 4:23 PM
hi.
check your router configuration.. I would guess its to blame.
Message 3 of 8
(1,031 Views)
19-08-2007 5:00 PM
Is it on any particular site? What router are you using?
Message 4 of 8
(1,031 Views)
19-08-2007 6:01 PM
Its doin g it on any website, im using a D link wirelss router, although the P{.C is conected via ethernet ( wired)
Message 5 of 8
(1,031 Views)
20-08-2007 7:57 AM
Have you made sure that the router has no idle time outs set? Check its configuration and, dependent on your router, either set the idle time out to 0 or tick the appropriate box to say "always on".
Message 6 of 8
(1,031 Views)
20-08-2007 6:30 PM
If you have a software firewall disable or uninstall it and see if the problem still occurs.
Do the same with any Anti Virus software.
Message 7 of 8
(1,031 Views)
20-08-2007 10:54 PM
The problem is either the router MTU is set wrong see
http://www.smallbusinesscomputing.com/webmaster/article.php/3491066
for details or your DNS is set wrong make sure your pc has the dns set to plusnet dns or use
* 208.67.222.222
* 208.67.220.220
This is assuming your router isnt dropping the connection for this check the logs
* 208.67.222.222
* 208.67.220.220
Message 8 of 8
(1,031 Views)
