Keep getting kicked from battlefield 3
- Keep getting kicked from battlefield 3
Re: Keep getting kicked from battlefield 3
04-07-2013 11:07 AM
How does the web browsing feel now?
Ex-Broadband Service Manager
04-07-2013 11:21 AM
Quote from: Kelly Give your router a graceful restart ......
Just to be sure you know what that means, but as much for anyone else reading, that means login to the Router and click Disconnect before restarting it. When it's rebooted, login and click Connect, to start a new PPP session.
04-07-2013 11:48 AM
Would you be able to create a TBB ping graph? You can find the details on how to here.
It may also be worth creating one for your BT connection too, so we can compare.
04-07-2013 12:02 PM
The session drops were probably me, I have been tinkering with routers this week to make sure ports forwarded etc. Here is my bt line speed test:
Download speedachieved during the test was - 51.41 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-52.51 Mbps .
Additional Information:
IP Profile for your line is - 52.51 Mbps
Upload speed achieved during the test was - 11.92Mbps
Again I normally get the full upload speed. I think the bt test is just flawed with upload speeds.
I actually just managed a whole game without getting kicked. I have to just hope it wasnt a fluke. My browsing seems to be stalling less which is good. Its a shame I can't see my router stats so that I could know the best time to shut down and leave the router for an hour to get a high sync back.
I might have a look at the TBB graph stuff shortly.
04-07-2013 12:32 PM
FYI if all you want to know is your Downstream sync speed then you can derive this from the Downstream BT IP Profile, profile x1.033 = Sync speed on FTTC
To ensure you get an accurate BT IP Profile, log in to the Modem/Router, in the Internet box, click Disconnect to drop the PPP Internet session (this is not the sync), wait 30 seconds then click Connect. This should ensure the relevant servers are updated with the current sync speeds.
DLM on FTTC, as you'd expect, is active all the time and there is no 10-day training period as such, but it can be especially aggressive in the first 2 days, it can be aggressive at other times as well, so as a general rule - do not turn off, reboot or disconnect the modem.
Should you ever have a real need to do that, the best method is to log into the Router, disconnect your PPP Internet session and then power down the Router. After about a minute power down the Modem and leave it off for at least an hour. Always best to do this in daytime.
When you power up again wait for sync and all lights on the Modem to stabilise before powering up the Router. When the Router has booted, login and and click Connect to establish a PPP session.
FTTC DLM has been reported to quite aggressively increase interleaving where it sees problems, but it will also reduce it over time if conditions improve. ISPs have no ability to turn Interleaving on or off on FTTC.
HTH.
04-07-2013 12:38 PM
04-07-2013 1:53 PM
Here is the tbb for the plusnet line. http://www.thinkbroadband.com/ping/share/ac972f7b240dbdabf6c92df88a71b851.html
04-07-2013 5:02 PM
04-07-2013 5:08 PM
04-07-2013 8:42 PM
Dave
05-07-2013 8:56 AM
05-07-2013 10:50 AM
05-07-2013 4:44 PM
05-07-2013 4:49 PM
05-07-2013 5:17 PM
