Kasperski message
Wardio2
Kasperski message
I keep getting a message from Kasperski saying "Connection to an insecure network 'PlusNet Wireless D34903 detected'. Any ideas what this is about?
Gel
Seasoned Pro
Fixes: 12
Re: Kasperski message
Seasoned Champion
Fixes: 44
I assume that it is detecting that you are using http addressing, hence someone listening in to your Wifi could evesdrop. Try installing the  https Everwhere extension to your browser : https://www.eff.org/https-everywhere. This forces the browser to use a secure link to a website should one be available (there generally is).
Kaspersky secure connection is an encrypted VPN.
Wardio2
Thanks. No, I'm using WPA2.
runhare
do you have any homeplugs on your home network?
Wardio2
No, nothing like that.
Seasoned Champion
Fixes: 44
Wardio2
Thanks Baldrick1. I've installed it. Fingers crossed!
Seasoned Champion
Fixes: 44
@Wardio2
Please let us know if that fixes your problem.
