Just switched to Extra (with Pro add-on) and have noticeable speed decrease
- Just switched to Extra (with Pro add-on) and have ...
04-02-2012 1:34 PM
Since the switch, both my wife and I have noticed web surfing and streaming speeds have noticeably decreased to the point that YouTube or Vimeo isn't worth visiting without starting playback and then pausing the video until it's completely downloaded.
I only have one phone line coming into my flat and this is what my router is connected to with a filter for my phone.
I'm quite unfamiliar with the technicalities of routers and the like though I gather I should provide the following information. Unfortunately I've had to reset my router recently due to a tendency for my home network to drop completely (can't even access the router's menu). I've found the only way to fix this is to physically reset the router. Not sure if this is related to the speed issue or not.
Any help would be greatly appreciated.
Router stats:
Uptime: 0 days, 1:05:16
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 5,792
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 31.5 / 54.0
SN Margin (Up/Down) [dB]: 18.0 / 9.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 5,183
CRC Errors (Up/Down): 0 / 14
HEC Errors (Up/Down): 0 / 15
BT speed test results:
Download speedachieved during the test was - 3733 Kbps
Additional Information:
Your DSL Connection Rate :5792 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 4500 Kbps
Current line speed:
Phone exchange: POPLAR
Estimated line speed: 5Mb (This may vary between 3.5Mb and 7.5Mb) - Checked on 2012-01-11 16:33:59
Current line speed: 21 Mb
Re: Just switched to Extra (with Pro add-on) and have noticeable speed decrease
04-02-2012 2:37 PM
Have you another router to try? From your comments about your TG585v7's tendency to freeze (here and in your Home LAN topic) I suspect your present router might be approaching failure.
David
04-02-2012 3:40 PM
Quote Are you in the process of being switched to 21CN/ADSL2+...
I'm afraid I'm not sure what that means or how to can check. Is this to do with the Pro add-on?
[EDIT] OK - After a bit of searching around I checked my exchange status here and found that 21CN is enabled
I do have an old Voyager 2110 router I could try to connect with though may take a bit of configuration to get it to connect. Are there any specific tests I should run with this different router?
04-02-2012 11:47 PM
I think it would be useful to try the Voyager if you can. I think those are supposed to be ADSL2+ compatible but sometimes prove troublesome. It should be OK before you are switched. Do you have any closed tickets or service notices on your account letting you know when the ADSL2+ switch is taking place?
If you do get the Voyager working the main thing to check are the router stats. See Kitz link http://www.kitz.co.uk/adsl/frogstats.php#15 if you are unsure how to get those. It might take 3-5 days before you notice any speed increase, depends how long the DLM takes to respond.
David
07-02-2012 12:45 PM
How's it all gone with the Voyager? Hope it's all working, though if the connection has stabilised and your sync rate has increased but the profile hasn't please let us know and we'll get an SNR reset done for you to let the line retrain at its best possible speed.
07-02-2012 8:06 PM
Repeat of tests below, doesn't look as though the speed is any better with this one according to the BT speed test.
I should say though that general surfing does feel a bit faster though (despite what the speed test says). Could it be that a slow internet connection could be caused by some sort of LAN issue?
Router stats
Line Mode | G.DMT | Line State | Show Time |
Latency Type | Interleave | Line Up Time | 00:01:04:49 |
Line Coding | Trellis On | Line Up Count | 1 |
Statistics | Downstream | Upstream | |
Line Rate | 5760 Kbps | 448 Kbps | |
Noise Margin | 8.7 dB | 18.0 dB | |
Line Attenuation | 56.0 dB | 31.5 dB | |
Output Power | 19.8 dBm | 12.3 dBm | |
K (number of bytes in DMT frame) | 181 | 15 | |
R (number of check bytes in RS code word) | 14 | 4 | |
S (RS code word size in DMT frame) | 1 | 4 | |
D (interleaver depth) | 32 | 8 | |
Super Frames | 228742 | 228740 | |
Super Frame Errors | 24 | 0 | |
RS Words | 15554486 | 3888580 | |
RS Correctable Errors | 3827 | 0 | |
RS Uncorrectable Errors | 176 | 0 | |
HEC Errors | 20 | 0 | |
OCD Errors | 0 | 0 | |
LCD Errors | 0 | 0 | |
ES Errors | 0 | 0 |
Download speedachieved during the test was - 3351 Kbps
Your DSL Connection Rate :5760 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
Current line speed
07-02-2012 11:42 PM
In terms of line performance the IP Profile should increase to 5000kbps, but it takes 4 days for the 20CN DLM to make that change - Wed afternoon based on the timing of your initial post.
It looks like your downstream target noise margin is 9dB. Has that been raised by the DLM because of disconnections at the normal 6dB? The increased target noise margin will have reduced sync speed by 500-750kbps.
David
08-02-2012 10:02 AM
As far as the noise margin, not really sure what's caused that. Would a few disconnections in a short space of time do this? If so, might be from when I was setting the router up as I did reset it a few times.
When checking things out this morning, it looked as though the noise margin had risen to 10dB even though there hadn't been any disconnections since.
08-02-2012 11:09 AM
If you disconnect then reboot ONCE when the noise margin is at it's highest to will resync at the target and you will see a higher sync speed.
The exchange seeing your line is stable and resetting the target may take some weeks. The best bet may be to make sure that you avoid resyncs for a number of days so that PN can see the line is stable and then you ask them to do a reset.
10-02-2012 10:02 PM
Updated stats after a few days using the Voyager 2110. So far have had no router freezes though did have a power cut today which reset the router.
Router stats
Noise Margin | 8.6 dB | 17.0 dB |
Speed test
Download speedachieved during the test was - 4073 Kbps
Additional Information: Your DSL Connection Rate :5760 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
Current line speed
While the speed test is a bit faster, I'm wondering whether I should be able to expect faster speeds considering the line rate my router has as well as the IP profile I have.
I don't appear to have been notified that my connection has been upgraded to ADSL2+ so maybe this would have a positive impact if the upgrade does take place?
Can anyone give me some feedback on what my expected line speeds should be with this connection and what else I can do to try and achieve it?
10-02-2012 10:30 PM
I thought I was doing well with 4,800kbps and a 51dB attenuation
However you could benefit from moving to 21CN but only because of the better IP profile system - this would give you 5080kbps profile immediately although your current sync rate on 20CN will give you a 5,000kbps profile eventually
Given all that there would be virtually no benefit in going to ADSL2 and it might even get worse
10-02-2012 11:09 PM
Overall though your sync speed is exceptional for your attenuation, it's tempting to suggest leaving things alone in case performance gets worse. However your opening post mentioned streaming problems - I wonder if these reflect significant transmission errors because the higher sync speed is not supportable (in a line performance sense)?
What do the error counters (those at the bottom of the longer stats you posted previously) look like after a full day's usage?
12-02-2012 12:11 AM
Seems there was an unexpected router reset during the night so not a full day's stats I'm afraid.
Most recent speed test results:
Statistics
Latency Type | Interleave | Line Up Time | 00:20:50:25 |
Line Rate | 5440 Kbps | 448 Kbps |
Noise Margin | 10.3 dB | 18.0 dB |
K (number of bytes in DMT frame) | 171 | 15 |
R (number of check bytes in RS code word) | 12 | 4 |
Super Frames | 4384407 | 4384405 |
Super Frame Errors | 175 | 0 |
RS Words | 302496738 | 75624143 |
RS Correctable Errors | 505696 | 0 |
RS Uncorrectable Errors | 1336 | 0 |
HEC Errors | 154 | 0 |
ES Errors | 0 | 0 |
Problems with streaming seems to have fixed themselves after switching routers.
12-02-2012 1:20 AM
If the connection remains stable with the Voyager and performs well over the rest of the weekend a line reset might be appropriate.
David
13-02-2012 11:57 AM
How's it been performing over the weekend.
Jojo
