Just switched from AOL to plusnet for higher speed and not getting it
- Just switched from AOL to plusnet for higher speed...
Re: Just switched from AOL to plusnet for higher speed and not getting it
21-03-2008 9:41 PM
Not yet i am new to forums and all this stuff.Before with aol i just plugged in and surfed.
Quote from: Strat It's not unknown for Plusnet to have a customer on the wrong profile.
Have you raised a ticket to bring this to Plusnet's attention through the official route?
21-03-2008 9:45 PM
wireless
Quote from: HPsauce Question 2?
21-03-2008 9:51 PM
What wireless adapter are you using and what signal strength/speed is the link?
Have you tried with the PC linked directly to the router with a LAN cable, assuming the PC has an ethernet port?
21-03-2008 9:57 PM
[Moderator's note by Jonathan (chillypenguin): Full quote of preceding post removed. The reply button is at the bottom of the thread about. ]
21-03-2008 10:17 PM
21-03-2008 10:30 PM
21-03-2008 10:34 PM
If not, can you try wired?
21-03-2008 10:36 PM
21-03-2008 10:46 PM
21-03-2008 11:04 PM
21-03-2008 11:07 PM
What did you change the MTU to on the PC?
21-03-2008 11:10 PM
21-03-2008 11:17 PM
An MTU of 1430 with a receive window of 166800 is worth trying (certainly works for me!).
21-03-2008 11:19 PM
Quote from: lochryan100 How do you change the MTU on my pc?
I thought you said you used DrTCP? That does it.
22-03-2008 9:55 AM
1. Try it with a cable rather than wireless
2. Check/adjust the RWIN - mine is 116000 (with an MTU of 1498 in both router and PC)
3. Check/adjust MTU - run ping tests if you can
These are my personal preferences of the order to do things, others may have different equally valid ideas.
Notes:
1. Use DrTCP to change RWIN; this is a global figure for all network adapters in the PC.
2. I found (via ping tests) that an MTU of 1500 was "flaky" so I use 1498
3. Change your router MTU via router admin (sounds like you've discovered how)
4. Change your PC MTU with Dr TCP - you need to select the appropriate adapter before saving!
5. An MTU can be too high, if in doubt reduce it a bit and try again (steps of 10 say)
6. An RWIN can be too low. There are several different recommendations I've seen based on MTU and line speed. Mine is around 100000 and I note another recommendation of 166800.
Only change 1 thing at once!
