Just ordered fibre for the second time
- Just ordered fibre for the second time
30-06-2014 9:53 AM
Could someone from Plusnet have a look at my order which is scheduled for July 9th.
As some while ago (18 months or so) due incorrect information by BT it seemed fibre was available it was only the exchange.
As a result an order was started but then aborted, this entailed router being ordered etc.
My concern is that is old order is on the system some where and just might cause hiccups with my current upgrade request.
Message 1 of 5
(793 Views)
4 REPLIES 4
Re: Just ordered fibre for the second time
30-06-2014 9:59 AM
As far as I can see the order has been accepted by our suppliers and is in a committed state. The order would have failed by this point if there was going to be a problem so I don't foresee any issues.
Message 2 of 5
(548 Views)
30-06-2014 10:25 AM
Many thanks ,
It was Plusnet end of things that I was concerned about in that I hoped no one would assume I already had the router etc.
Message 3 of 5
(548 Views)
30-06-2014 10:27 AM
Ah - I see. We've got your order and I can see you've opted for the router. I've posted it out early anyhow, just so you have it well in good time.
Message 4 of 5
(548 Views)
30-06-2014 10:30 AM
Thank you
Message 5 of 5
(548 Views)
