Just ordered Fibre - whats the best router to get
jklondon
Looking to invest in a better router than the cr*p plusnet will provide. Want a single device so a combined modem and router - any suggestions? Been looking at BT Home Hub 5 as an idea.
mattverinder
Re: Just ordered Fibre - whats the best router to get
Hi i can recommend the Draytek Vigor 2850n using currently, new model Draytek Vigor 2860n both support VDSL2.
lexhamilton
I've been very happy with the Asus RT-N66U router.  Has some great speeds across the property and maintains a high throughput even at the extremities of it's range.
Simple to set up too, but does allow some geeking out for QOS and traffic management.  If that's your thing. ;-)
http://www.asus.com/Networking/RTN66U/
Finguz
Another vote for the RT-N66U here, great bit of kit!  Cool
Kielty
If you are looking for 1 box the Asus DSL-N66U...  This is the RT-N66U router with a modem built in (ADSL and VDSL)...
gwillym
BT HomeHub 5
AVM Fritz!Box Fon WLAN 7390  Tongue
http://www.thinkbroadband.com/hardware/reviews/73-fritzbox-7390.html
Call me 'w23'
SimonDS
Asus rt n66u - awesome wfi range
The dsl version is not the same router with a modem built in. The cpu is different.
