Just migrated in....
- Just migrated in....
20-02-2013 2:55 PM
As I've just returned after 6 years away, I don't want to moan, or ask support to look at it until I know.
Current stats are this on a Netgear DGN22000
ADSL Link Downstream Upstream
Connection Speed 13079 kbps 445 kbps
Line Attenuation 28.0 db 15.3 db
Noise Margin 6.0 db 30.0 db
I've had it at this before:
Connection Speed 17481kbps 1244kbs
Line Attenuation 28.5db 16.1db
Noise Margin 2.9db 5.5db
Then Zen bumped my SNR up to 6.0db downstream and stuck interleaving on my line, as I had a faulty router, giving me the 11.5 down and 1.2up., but they never ever took the interleaving off.
All advice welcomed. It's good to be back
Re: Just migrated in....
20-02-2013 2:59 PM
Your downstream SNR is the default of 6.0dB. If your line stays nice and stable for "enough time", the DLM should adjust that down to 3.0dB and give you back an approximation to your previous speeds.
20-02-2013 3:20 PM
At the moment, Interleaving i set to 'Auto' on your line. This means that it will enable itself if your line starts to drop.
We can uncap your upload speeds if you would like us too. I think the only real way we are going to be able to increase your sync speeds are by reducing your SNR Target from 6db down to 3db, this may cause your line to become unstable though.
Let me know if there is anything further I can do to help
20-02-2013 3:34 PM
If you could uncap my upstream speed that would be great !
Could I try the 3db SNR too please ?
I assume that if the line does become unstable, the SNR will just go back to 6db ?
The reason I asked about the interleaving is because my ping was about 32ms.
Thanks.
Peter
20-02-2013 3:39 PM
Yep that's no problem, I'll get an order placed for your upload speeds to be uncapped.
If we put you on a 3db target, if your connection starts to drop, the DLM will automatically push you back up to 6db (or should do.)
20-02-2013 3:44 PM
It's so good to have brilliant customer service
Peter
20-02-2013 3:58 PM
I'll wait for the order to complete tomorrow so I can change all of the SNR settings together.
20-02-2013 11:40 PM
Just in case you were wondering, I have rebooted my router tonight in order to get a static IP.
I thought I had better after looking at my usage, which according my account page was 394.36MB !
After all, I only went live at about 12.30 and haven't downloaded anything, just browsed webpages.
Anyway, it's not a line drop
20-02-2013 11:58 PM
21-02-2013 10:44 AM
Quote from: Anotherone In order to get a "static IP" ? I take it you've paid for one an that was just to get connected to it? You don't need to reboot to do things like that by the way, or to Gateway hop. Just login to the modem/router and Disconnect your PPP Internet session and then wait about 30 seconds and then click Connect.
That's what I did.
However, everytime some options are changed, the router reboots anyway. (e.g. ticking "use static ip")
21-02-2013 10:53 AM
Quote from: 2pods However, everytime some options are changed, the router reboots anyway. (e.g. ticking "use static ip")
Some routers do that. I don't really understand why as usually the router can just refresh options whilst it's turned on. It is annoying for DLM though, because if one changes many options, it can upset DLM due to it seeing resets and it will give one lower speeds.
21-02-2013 11:00 AM
Anyway, upstream speed has been uncapped. SNR not reset to 3db yet though.
21-02-2013 11:39 AM
21-02-2013 11:47 AM
I appreciate it.
Peter
