Just joined
- Just joined
Just joined
24-05-2013 8:43 PM
Hello,
Just ordered and moving from BE. I am getting fibre as well so i have some questions if people are able to spare me 5 mins. They are sending me out a router and an engi is coming out as well. What is he coming out to do?
Richard
Richard
Message 1 of 8
(1,108 Views)
7 REPLIES 7
Re: Just joined
24-05-2013 9:22 PM
He will be coming into your house to fit a filtered faceplate, plug in a modem that he brings with him and make sure its working and that you are connected
Message 2 of 8
(623 Views)
Re: Just joined
24-05-2013 9:29 PM
So the router that plusnet are sending me, will plug into the device that the engi is bringing with him?
Message 3 of 8
(623 Views)
Re: Just joined
24-05-2013 9:30 PM
He will also do some work at your BT cabinet where he will connect the incoming fibre line to your outgoing copper line. It's at this stage where your phone line will go dead for a few minutes.
Message 4 of 8
(623 Views)
Re: Just joined
24-05-2013 9:32 PM
Quote from: trekrich So the router that plusnet are sending me, will plug into the device that the engi is bringing with him?
Correct
Message 5 of 8
(623 Views)
Re: Just joined
24-05-2013 9:42 PM
nice! at the moment with be i have their router. Its a Technicolor TG582n, but the upnp and other things on it are really dire. So i have it bridged over to a apple time capsule. This does all the routing wifi and everything, i have stuff setup on my network with static addresses. Can i plug my apple device into device that the engi is bringing with him? Does it use PPOE or something?
Thanks for your help so far!
Richard
Richard
Message 6 of 8
(623 Views)
Re: Just joined
24-05-2013 10:37 PM
Yes, you can use your Apple Time Capsule to connect into the BT modem using PPPoE. If in your current bridging setup you have it logging in using PPPoE then it should work in the new fibre setup as is.
That's RPM to you!!
Message 7 of 8
(623 Views)
Re: Just joined
28-05-2013 11:27 AM
Message 8 of 8
(623 Views)
