Just joined from BE - ping spikes making gaming unplayable
- Just joined from BE - ping spikes making gaming un...
Re: Just joined from BE - ping spikes making gaming unplayable
09-09-2013 8:53 AM
I've changed your profile back to 4.5Mb/s.
09-09-2013 9:25 AM
Ex-Broadband Service Manager
09-09-2013 9:59 AM
09-09-2013 10:14 AM
09-09-2013 12:20 PM
11-09-2013 7:45 PM
During the day (off peak), I can't induce any lag with streaming, but in the evenings, the lag whilst streaming is there (unless something happened today):
ping -t 185.12.240.110
Pinging 185.12.240.110 with 32 bytes of data:
Reply from 185.12.240.110: bytes=32 time=59ms TTL=53
Reply from 185.12.240.110: bytes=32 time=62ms TTL=53
Reply from 185.12.240.110: bytes=32 time=60ms TTL=53
Reply from 185.12.240.110: bytes=32 time=61ms TTL=53
Reply from 185.12.240.110: bytes=32 time=68ms TTL=53
Reply from 185.12.240.110: bytes=32 time=55ms TTL=53
Reply from 185.12.240.110: bytes=32 time=80ms TTL=53
Reply from 185.12.240.110: bytes=32 time=156ms TTL=53
Reply from 185.12.240.110: bytes=32 time=64ms TTL=53
Reply from 185.12.240.110: bytes=32 time=71ms TTL=53
Reply from 185.12.240.110: bytes=32 time=63ms TTL=53
Reply from 185.12.240.110: bytes=32 time=70ms TTL=53
Reply from 185.12.240.110: bytes=32 time=67ms TTL=53
Reply from 185.12.240.110: bytes=32 time=81ms TTL=53
Reply from 185.12.240.110: bytes=32 time=151ms TTL=53
Reply from 185.12.240.110: bytes=32 time=79ms TTL=53
Reply from 185.12.240.110: bytes=32 time=96ms TTL=53
Reply from 185.12.240.110: bytes=32 time=195ms TTL=53
Reply from 185.12.240.110: bytes=32 time=177ms TTL=53
Reply from 185.12.240.110: bytes=32 time=185ms TTL=53
Reply from 185.12.240.110: bytes=32 time=117ms TTL=53
Reply from 185.12.240.110: bytes=32 time=120ms TTL=53
Reply from 185.12.240.110: bytes=32 time=169ms TTL=53
Reply from 185.12.240.110: bytes=32 time=127ms TTL=53
Reply from 185.12.240.110: bytes=32 time=157ms TTL=53
Reply from 185.12.240.110: bytes=32 time=100ms TTL=53
Reply from 185.12.240.110: bytes=32 time=125ms TTL=53
Reply from 185.12.240.110: bytes=32 time=146ms TTL=53
Reply from 185.12.240.110: bytes=32 time=261ms TTL=53
Reply from 185.12.240.110: bytes=32 time=92ms TTL=53
Reply from 185.12.240.110: bytes=32 time=269ms TTL=53
Reply from 185.12.240.110: bytes=32 time=285ms TTL=53
Reply from 185.12.240.110: bytes=32 time=324ms TTL=53
Reply from 185.12.240.110: bytes=32 time=876ms TTL=53
Reply from 185.12.240.110: bytes=32 time=453ms TTL=53
Reply from 185.12.240.110: bytes=32 time=154ms TTL=53
Reply from 185.12.240.110: bytes=32 time=73ms TTL=53
Reply from 185.12.240.110: bytes=32 time=351ms TTL=53
Reply from 185.12.240.110: bytes=32 time=263ms TTL=53
Reply from 185.12.240.110: bytes=32 time=109ms TTL=53
Reply from 185.12.240.110: bytes=32 time=181ms TTL=53
Reply from 185.12.240.110: bytes=32 time=208ms TTL=53
Reply from 185.12.240.110: bytes=32 time=137ms TTL=53
Reply from 185.12.240.110: bytes=32 time=65ms TTL=53
Reply from 185.12.240.110: bytes=32 time=76ms TTL=53
Reply from 185.12.240.110: bytes=32 time=89ms TTL=53
Reply from 185.12.240.110: bytes=32 time=94ms TTL=53
Reply from 185.12.240.110: bytes=32 time=69ms TTL=53
Reply from 185.12.240.110: bytes=32 time=101ms TTL=53
Ping statistics for 185.12.240.110:
Packets: Sent = 81, Received = 81, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 55ms, Maximum = 876ms, Average = 123ms
How do the speed profiles look at the moment?
12-09-2013 8:36 AM
12-09-2013 10:03 AM
Not sure why you had poor performance last night though as the profile was OK. We'll take a look to see if there were any issues last night.
12-09-2013 10:32 AM
The performance wasn't consistently bad, as such, but similar (although not identical) to the latency introduced when streaming. The behaviour was different, as follows:
1. Latency (in game/monitored via a ping to a game server) is good (~60ms on the ping trace from yesterday).
2. Fire up YouTube, and stream a couple of videos.
3. The 'lumpy' latency is then experienced (as per the trace). It bounces up and down a lot more than I've observed before. Previously, streaming would brick the latency in excess of 200ms.
4. I'm only seeing it at peak times.
Would it help if I initiated the formal complaint procedure? I've had latency issues from day one for 6 months now, and we're not getting very far.
12-09-2013 11:00 AM
13-09-2013 8:27 AM
Have you identified the bug yet? How long will it take to fix?
13-09-2013 9:10 AM
13-09-2013 9:26 AM
Have you determined why my PN speed profile is being reset? When can I expect a fix?
13-09-2013 12:35 PM
13-09-2013 12:38 PM
