Just joined from BE - ping spikes making gaming unplayable
- Just joined from BE - ping spikes making gaming un...
Re: Just joined from BE - ping spikes making gaming unplayable
24-03-2013 12:39 PM
25-03-2013 1:04 PM
We'll be updating your fault ticket shortly.
25-03-2013 5:54 PM
ping -t 195.166.128.183
Pinging 195.166.128.183 with 32 bytes of data:
Request timed out.
Reply from 195.166.128.183: bytes=32 time=248ms TTL=126
Reply from 195.166.128.183: bytes=32 time=253ms TTL=126
Reply from 195.166.128.183: bytes=32 time=263ms TTL=126
Reply from 195.166.128.183: bytes=32 time=245ms TTL=126
Reply from 195.166.128.183: bytes=32 time=264ms TTL=126
Reply from 195.166.128.183: bytes=32 time=246ms TTL=126
Reply from 195.166.128.183: bytes=32 time=242ms TTL=126
Reply from 195.166.128.183: bytes=32 time=305ms TTL=126
Reply from 195.166.128.183: bytes=32 time=240ms TTL=126
Reply from 195.166.128.183: bytes=32 time=247ms TTL=126
Reply from 195.166.128.183: bytes=32 time=290ms TTL=126
Ping statistics for 195.166.128.183:
Packets: Sent = 13, Received = 12, Lost = 1 (7% loss),
Approximate round trip times in milli-seconds:
Minimum = 240ms, Maximum = 305ms, Average = 257ms
Control-C
Reply from 195.166.128.183: bytes=32 time=445ms TTL=126
Reply from 195.166.128.183: bytes=32 time=477ms TTL=126
Reply from 195.166.128.183: bytes=32 time=70ms TTL=126
Reply from 195.166.128.183: bytes=32 time=351ms TTL=126
Reply from 195.166.128.183: bytes=32 time=375ms TTL=126
Reply from 195.166.128.183: bytes=32 time=386ms TTL=126
Reply from 195.166.128.183: bytes=32 time=385ms TTL=126
Reply from 195.166.128.183: bytes=32 time=384ms TTL=126
Reply from 195.166.128.183: bytes=32 time=380ms TTL=126
Reply from 195.166.128.183: bytes=32 time=408ms TTL=126
Reply from 195.166.128.183: bytes=32 time=459ms TTL=126
Reply from 195.166.128.183: bytes=32 time=503ms TTL=126
Reply from 195.166.128.183: bytes=32 time=500ms TTL=126
Reply from 195.166.128.183: bytes=32 time=491ms TTL=126
Reply from 195.166.128.183: bytes=32 time=531ms TTL=126
Reply from 195.166.128.183: bytes=32 time=499ms TTL=126
Reply from 195.166.128.183: bytes=32 time=530ms TTL=126
Reply from 195.166.128.183: bytes=32 time=514ms TTL=126
Packets: Sent = 18, Received = 18, Lost = 0 (0% loss),
Minimum = 70ms, Maximum = 531ms, Average = 427ms
Control-C
25-03-2013 7:33 PM
http://community.plus.net/forum/index.php/topic,111170.0.html
25-03-2013 10:30 PM
Out of interest, what issues were found on your line that prompted Chris to ask you to raise a fault?
26-03-2013 7:30 AM
FEC Errors (Up/Down): 0 / 1.466.662
This will be a function of the amount of traffic I assume. This morning I'm getting about 100/min whilst VPN-ed into work and using VoIP, but the pings are fine. I'm not getting ping spikes at this time - still seems more like congestion to me at this stage.
26-03-2013 2:27 PM
26-03-2013 3:34 PM
26-03-2013 4:17 PM
Pinging the gateways won't show anything relevant I'm afraid. Ping traffic to them isn't prioritised, so the ping times going up when the gateways are busy is normal and in fact as designed.
You'd need to ping an external server (ideally one you connect to when gaming) to show any issues - if you could do that it'll show much more relevant information.
26-03-2013 6:52 PM
Is ICMP traffic shaped for all hosts? I'm thinking *any* ping test would therefore be invalid.....I'll reconfigure SmokePing for some game servers.
26-03-2013 7:14 PM
26-03-2013 7:26 PM
26-03-2013 8:27 PM
27-03-2013 9:21 AM
I had some interesting pings yesterday when using a couple of machines on wireless - my wireless performance was pretty terrible (thanks to the abundance of TalkTalk routers around here hogging channels) but pings from the wired server was fine.
Not sure if it was the router struggling or congested wireless but things went rather sluggish for a bit. (I use a 3rd Party router - not the one supplied by PN)
27-03-2013 9:36 AM
