Just joined, connection looking slow
- Just joined, connection looking slow
02-04-2013 1:14 PM
I have just moved over from BE and so far I'm not impressed with the speed.
I was given a speed estimate of 10mb +/- 1mb. When I first connected I was getting
about 4.6 mb which dropped the next day to 2.6 then again the next day to 0.2.
It has gone up to 2.6 but that is still no where near the 10mb I was promised.
BE speed was a constant 5mb give or take little. I realise I need to wait 10 days
for the line to settle but this is day 7 and there seems like no sign of improving.
It seems strange how the speed is exactly 2.61 every time I test it with speedtest.net
When I was with BE no two tests were ever EXACTLY the same speed.
Is this speed normal for a new connection? will I see it jump up to 10mb on day 10?
Bob
Re: Just joined, connection looking slow
02-04-2013 1:36 PM
Ignore the bit about test socket at present
02-04-2013 1:43 PM
Im at work at the moment.
Thanks again
Bob
02-04-2013 5:40 PM
Here are the results from the DSL connection after selecting
the "View More...." link
DSL Connection
Link Information
Uptime: 1 day, 20:44:39
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 448 / 3.065
Data Transferred (Sent/Received) [MB/MB]: 45,71 / 334,85
[color=black]BT speed test results are as follows
1. Best Effort Test: -provides background information.
Download Speed
2.64 Mbps
0 Mbps 4 Mbps
Max Achievable Speed
Download speedachieved during the test was - 2.64 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
IP Profile for your line is - 2.7 Mbps
Upload Speed
0.38 Mbps
0 Mbps 0.45 Mbps
Upload speed achieved during the test was - 0.38Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
[/color]
And finally my current line speed
Phone exchange:
BURGESS HILL
Estimated line speed:
10Mb (Accurate to within +/- 1Mbit) - Checked on 2013-03-31 11:45:42
Current line speed:
4.5 Mb
Hope this helps.
Many thanks
Bob
02-04-2013 5:45 PM
We need attenuation, noise margin and, if possible, the errors
02-04-2013 5:48 PM
Thanks for the link, results are as follows
DSL Connection
Link Information
Uptime: 1 day, 21:04:44
Data Transferred (Sent/Received) [MB/MB]: 47,60 / 342,62
Output Power (Up/Down) [dBm]: 11,8 / 20,3
Line Attenuation (Up/Down) [dB]: 23,5 / 41,5
SN Margin (Up/Down) [dB]: 15,0 / 7,4
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Link (Remote): -
Error Seconds (Local/Remote): 66 / 0
FEC Errors (Up/Down): 37 / 1.111.700
CRC Errors (Up/Down): 15 / 111
HEC Errors (Up/Down): 4 / 525
03-04-2013 7:07 AM
Can anyone see any problems with my router stats?
I don't understand why my speed is always exactly the same,
when I was with BE no two speed checks were ever the same, it's
like my line limited but the router wants to go faster.
Bob
03-04-2013 10:13 AM
03-04-2013 10:29 AM
If you have a master socket with a removable lower half you need to connect to the test socket inside (this will disconnect any other extension phones sockets). Leave it for a few hours and then post the detailed router stats again. That will indicate if the problem is inside or outside your house.
I know FTTC is available in a many parts of Burgess Hill - is it available to you? http://www.dslchecker.bt.com/adsl/adslchecker.welcome will tell you that.
03-04-2013 1:06 PM
I was connected to the one furthest away from where the line enters the house
so I have moved the router upstairs to the nearest socket, it looks like it has
two cables entering it, probably one in and one out.
There was an extension in the upstairs socket that was going no where so I have removed it.
I will leave it plugged in over the afternoon when I go back to work and post the results
when I get home tonight.
Many thanks for trying to help.
Bob
03-04-2013 1:23 PM
03-04-2013 5:34 PM
socket and both fitted with the new filters supplied by Plusnet.
Here are the router stats since 1:00 PM today.
Link Information
Uptime: 0 days, 4:36:21
Bandwidth (Up/Down) [kbps/kbps]: 448 / 3.070
Data Transferred (Sent/Received) [MB/MB]: 6,96 / 31,85
Output Power (Up/Down) [dBm]: 12,0 / 19,8
Line Attenuation (Up/Down) [dB]: 23,6 / 41,5
SN Margin (Up/Down) [dB]: 15,6 / 8,0
Error Seconds (Local/Remote): 5 / 0
FEC Errors (Up/Down): 0 / 37.978
CRC Errors (Up/Down): 0 / 5
HEC Errors (Up/Down): 0 / 35
Line speed still tests at 2.61Mb
All the best
Bob
04-04-2013 9:44 AM
04-04-2013 1:15 PM
All the best
Bob
My latest router stats.
Link Information
Uptime: 0 days, 16:14:01
Bandwidth (Up/Down) [kbps/kbps]: 448 / 3.067
Data Transferred (Sent/Received) [MB/MB]: 16,33 / 182,03
Output Power (Up/Down) [dBm]: 12,0 / 19,5
SN Margin (Up/Down) [dB]: 17,5 / 6,1
Error Seconds (Local/Remote): 15 / 0
FEC Errors (Up/Down): 0 / 305.369
CRC Errors (Up/Down): 0 / 35
HEC Errors (Up/Down): 0 / 138
04-04-2013 3:32 PM
