Just how are profiles applied?
- Just how are profiles applied?
- « Previous
- 1
- 2
- Next »
Re: Just how are profiles applied?
22-11-2009 10:03 AM
Now I'm really puzzled....tho my sync rate has been above 1800 for a few days, and my BT profile is and has been at least 1500 for at least 3 days, this morning I found my Plusnet profile has dropped from 1500 to 750 overnight....tho the BT one is still 1500 ! Even so, despite the Plusnet profile of 750, I'm still achieving 1400+ on speedtests - so the Plusnet profile ISN'T having an effect.
What really is the Plusnet profile about?
22-11-2009 10:39 AM
22-11-2009 10:44 AM
Quote I'm still achieving 1400+ on speedtests - so the Plusnet profile ISN'T having an effect
dont reboot your router or disconnect your ppp session other wise this bugged out PN profile will no doubt come into force on your line, wait for PN to sort it out.
as anotherone has said there seems to be a bug or 2 about and ive seen the same happen to some one else in the past week
22-11-2009 10:50 AM
22-11-2009 10:58 AM
(I'm already at target SNRM 15, so not too worried about 2 or 3 resyncs/reboots within 10 mins).
22-11-2009 11:43 AM
22-11-2009 2:05 PM
When I'm testing routers, at some point I need to be a close as possible (above) to a profile boundary that I'm trying to reach (usually the highest I think likely) so that I don't carry unneccesary excess sync (and consequent higher errors). That means that any time I need to adjust to a new profile boundary, I usually have to have 2 or 3 resyncs - usually with a tweak-SNRM adjustment between each - or, in the case of the Billion 7300, by resyncing at a moment in time where the difference between 6 and the prevailing SNRM seems likely to result in producing the required rate. When my target SNRM was 9, I always did this very cautiously indeed over an hour or so, but as I'm back at 15, I don't now worry. Given my previous experiences in asking for SNRM reduction, I'm unlikely to ask again, tho I may (!) try a hands-off-for-4-weeks.....realistically, I'm fairly content using the tweakable or hardwired SNRM routers. I may even put my excess HGVs onto Ebay!
22-11-2009 2:54 PM
22-11-2009 3:07 PM
24-11-2009 8:55 AM
Very odd!
Re:Just how are profiles applied?
24-11-2009 11:19 AM
I've just checked your profile at this end and it's set to 1500, though the BT profile is set at 750 on a couple of systems. Not sure why that is, but it should sort itself out soon.
24-11-2009 11:58 AM
- « Previous
- 1
- 2
- Next »
