Just got fibre installed, but speeds slower than estimated?
dneill2006
Fibre install went without a hitch today, all working great but speeds are a little slower than estimated.
This is the fastest I could get after a few speed tests:
But my estimated speeds are 80/20, and on the BT Wholesale Broadband Performance Test my IP Profile is 77.34/20.
Am I likely to see the speed go up during/after the 10 day stabilization period?
Fixes: 224
Re: Just got fibre installed, but speeds slower than estimated?
that is about as fast as anyone on FTTC is likely to get and is pretty impressive.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
dneill2006
Ah OK, thanks. Sorry new to FTTC.
adie:quote
Fixes: 55
Your sync speed will be close to 80Mbps. The difference is due to protocol and real world overheads.
David
