Just connected to fibre
- Re: Just connected to fibre
22-04-2013 12:06 PM
Just been connected to fibre this morning i am around 400 metres from the cab and was expecting around
59Mb. so done a few speedtests from the modem and as you can see from my sig i am getting close to 80Mb.
Question is, is this likely to stay at this speed or will it gradually fall back to around 60Mb.
Message 1 of 5
(837 Views)
4 REPLIES 4
22-04-2013 12:13 PM
I had an estimated 50.4 Mb but synced initially at 72 ish, it's gone down to around 65 but is currently back up at 74.
I think it all depends on how stable your connection is at the higher speeds.
Message 2 of 5
(434 Views)
22-04-2013 12:18 PM
Thanks picbits so hopefully it will stay around these speeds,just a bit of a shock seeing the speeds i am getting
when i am use to around 4Mb on a good day.
Message 3 of 5
(434 Views)
22-04-2013 12:52 PM
I'm due an install on Thursday and BT's estimate was a massive 9.9DL (currently at 6 on ADSL so not exactly a great upscale!)
Dave on here did run through the table and estimated much higher based on my cab distance estimate at 450m, but the figures here are certainly encouraging
Fingers crossed
Fingers crossed
Message 4 of 5
(434 Views)
22-04-2013 1:54 PM
You'll get "bored" of the speed eventually
Seriously though, I think that a 20-30Mb connection is more than enough for most people / families. I rarely use more than that unless I'm downloading a Linux image or similar.
Fingers crossed you'll keep your speeds
Message 5 of 5
(434 Views)
