Just checking before complaining!
- Just checking before complaining!
Re: Just checking before complaining!
12-08-2010 1:01 PM
12-08-2010 3:07 PM
Quote If there have been floods in the area then it's certainly possible that some wiring has been damaged / corroded slightly.
My area wasn't affected at all by the flood water. The next town was but the internet in my town was off for 24hrs. That's why have left it for so long before doing anything because I had put it down to maybe some of their traffic might have being going through our exchanges.
Looking at other peoples connections no one else seems to be affected.
I don't generally move my equipment around, I have only been rebooting my router once per day to test my sync speed after rebooting other than this I only reboot once a week on a saturday morning.
I have never suffered any disconnections online, they may be happening without me know though the router is in the hallway next to the socket.
I'll try and get a longer graph. I have noticed that late in the evenings my snr goes wild. Its stable at 12 db all day and early evening but later on it plummets dropping anywhere between 2 and 12 could this be an answer?
I can't find what's causing the noise, possibilities are my old lap top with a dodgy battery or maybe the ethernet wall plug adapters. I did try testing without the adapters and there was a slight improvement but not much.
12-08-2010 3:36 PM
12-08-2010 5:09 PM
12-08-2010 5:11 PM
16-08-2010 9:02 PM
PN rang me and said that my ip profile has been fluctuating between 2500 and 3000 for the last 6 months, not sure why that would be.
17-08-2010 11:12 AM
We have to generate the graphs manually, please post back when the 72 hours have elapsed and we can post them for you.
17-08-2010 11:19 AM
Now 48 hrs into the test. The only thing noticeable from the graphs so far is that my SNR goes wild at street lighting times. I tried last night with the ethernet wall plugs disconnected, the only thing going on was the main pc directly into the xte face plate. I think I can now rule out noise from my fish tank pumps etc as there was nothing significant on the graphs when this was on with everything running so I'm guessing here the wall plugs and the tank are not creating the noise on the line.
That leads me to other possibilities, what about the phone line wired into the back of the xte face plate, could it be acting as an antennae? I thought that wiring it directly into the face plate should eliminate this problem or have I picked that up wrong?
The noise at street lights on until off is a worry, my snr often gets down in the minus figures from generally 12db although it has to be said I have yet not suffered any disconnections. The lamp post out the back of my house went out a few months back so utilities people came out and changed a fuse on it, a couple of week after that there was a fireworks display on it with blue flames arching out in the rain. Turned out that a gland had been split and water was getting into the live wires anyway road was dug up and it was fixed, could this be a suspect?
Only other things is router which I'm going to setup my free 1 port one supplied by PN that's never been used, my old linksys wag354g is prob 7 or 8 years old and may be failing but seems to much of a coincidence that all the noise starts and finishes in street lighting times.
17-08-2010 11:30 AM
17-08-2010 11:51 AM
I got grief from Sky last time I pulled these wires which caused problems previously but that was on an extension cable plugged into face plate as oppose to hard wired to the back.
I think I'm out of contract with Sky so might be worth pulling them out again see if it makes a difference?
17-08-2010 12:24 PM
17-08-2010 1:35 PM
If I pull these wires then put a standard phone connector on the end then I surely don't need a filter as the face plate has built in filter?
There is some evidence to support the case which would make sense, after the floods things were running on red at the exchange and about two months afterwards I had the Sky wires fitted! Maybe it was just recovering when the lines made it worse
I suppose I will be ok stopping my 72hours test while I pull the wires or wait until it's finished?
17-08-2010 1:40 PM
17-08-2010 2:01 PM
17-08-2010 2:07 PM
Quote from: AverageWhiteBloke The faceplate filters the adsl signal from the phone
Sounds like it!
