Just Joined - No Internet but Solid Green Lights
- Just Joined - No Internet but Solid Green Lights
- « Previous
- Next »
Re: Just Joined - No Internet but Solid Green Lights
25-08-2014 1:19 PM
Oh well, at least it's going back to BT for investigation.
Message 31 of 34
(318 Views)
26-08-2014 4:52 PM
Hi Namster
I've had a look over the account and it seems you've raised a fault with us already.
In the mean time, I've corrected some profile information regarding your service so when this problem's resolved you should be ready to get your correct speeds
@Quicky
Thanks for letting us know. I just double checked your account to ensure there aren't any issues and everything looks great!
@Quicky
Message 32 of 34
(318 Views)
28-08-2014 3:48 PM
fyi update, BT engineer changed the faceplate socket but still got only 11Mbps, after waiting 15 minutes and speaking to his colleagues they made some changes on the profile, Now see as below with CAT5 cable from Router to Laptop.., is there anything else you need to check for stability ?
Message 33 of 34
(318 Views)
29-08-2014 11:56 AM
I expect it's a case of keep an eye on it. Whatever you do don't reboot the Modem for the next couple of days or at all unless absolutely necessary - remember what I said in reply #12. Rebooting the Router shouldn't be an issue but remember to Logoff/Disconnect the PPP session first and Connect again after.
Use the BT Speedtest Diagnostics if it's working for you, remember to do some speedtests at off-peak times which will tell you more about your connection. Speedtests at peak times will reflect how congested the Network may be (primarily the BT part) not often Plusnet's end.
Message 34 of 34
(318 Views)
- « Previous
- Next »
