Just Got Connected / Need Help
- Re: Just Got Connected / Need Help
03-05-2012 4:21 PM
03-05-2012 4:38 PM
03-05-2012 4:40 PM
03-05-2012 4:43 PM
03-05-2012 4:44 PM
03-05-2012 5:01 PM
I've placed an order to uncap your upstream, speed. This should take effect tomorrow.
Jojo
03-05-2012 5:03 PM
03-05-2012 5:32 PM
I've changed your speed profile now - It would have changed automatically. You should see the change shortly. To log out of the router, click admin at the top right and then 'switch to another user' this should log you out.
Jojo
03-05-2012 5:37 PM
04-05-2012 2:26 AM
Quote from: tomxlisa Perfect, how do i get to that from in the router without using the link?.
Login to the router, click Broadband Connection, then DSL Connection, then Details
If you want to copy the information into a post, click to the left of Uptime and drag the pointer to the end of the HEC Errors line.
Right click in the highlighted area and select Copy
Right click in the forum post text box and select Paste.
(These instructions are for a TG585v8; I am assuming the TG582n is similar.)
04-05-2012 9:38 AM
I've just checked on our supplier's system and the upstream order has gone through, so you should be seeing the increase now.
Jojo
06-05-2012 4:15 AM
