Junction box on top of pole - should it look like this
Fixes: 62
if it shouldn't how do I get it fixed
Fixes: 20
Re: Junction box on top of pole - should it look like this
It should be closed at least.
I assume that it isn't causing noisy lines? If so then they are probably not interested in repairing it.
knowdice
The black box on the left hand side is covered Ok.
Bit at the back looks like a mounting frame to fit the curve of the pole...
Fixes: 20
Here's mine to compare it to.
Fixes: 65
Hi all,
It would be harder for us to broach with Openreach if unless there is any noticeable issues such as noise on the line. However we should still be able to raise a damage report with them.
Adam
 Adam Walker
Fixes: 62
I have just replaced the filter and if it doesn't solve the problem I will be raising a fault
198kHz
All Star
Fixes: 10
BT external network problems can reported direct to Openreach
Remember you are unique - just like everyone else
Fixes: 62
New picture - taken at full zoom with my main camera
It looks OK but the spiders web is nice
