Junction box on top of pole - should it look like this
- Re: Junction box on top of pole - should it look l...
05-03-2013 11:09 AM
Message 1 of 8
(1,403 Views)
7 REPLIES 7
Re: Junction box on top of pole - should it look like this
05-03-2013 11:13 AM
It should be closed at least.
I assume that it isn't causing noisy lines? If so then they are probably not interested in repairing it.
Message 2 of 8
(645 Views)
05-03-2013 11:15 AM
The black box on the left hand side is covered Ok.
Bit at the back looks like a mounting frame to fit the curve of the pole...
Message 3 of 8
(645 Views)
05-03-2013 11:18 AM
Here's mine to compare it to.
Message 4 of 8
(645 Views)
05-03-2013 3:43 PM
Hi all,
It would be harder for us to broach with Openreach if unless there is any noticeable issues such as noise on the line. However we should still be able to raise a damage report with them.
Adam
Adam
Message 5 of 8
(645 Views)
05-03-2013 4:59 PM
I have just replaced the filter and if it doesn't solve the problem I will be raising a fault
Message 6 of 8
(645 Views)
05-03-2013 5:19 PM
BT external network problems can reported direct to Openreach
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Message 7 of 8
(645 Views)
06-03-2013 4:21 PM
New picture - taken at full zoom with my main camera
It looks OK but the spiders web is nice
Message 8 of 8
(645 Views)
