John Lewis broadband shows instead of plusnet...help!
Ludo
Hi, my builder ripped of telephone line accidentaly, when i reconnected and tested phone all was ok however when im trying to sign in to broadband John Lewis sign in shows! Whats wrong hereHuh Please help...
Fixes: 103
Re: John Lewis broadband shows instead of plusnet...help!
Are you able to log into your router and check the broadband username it's configured to connect to?
I suspect it will be set to either tr069@plusdsl.net or setup@john-lewis.com.
If that's the case, you need to disconnect and re-enter your Plusnet broadband username and password which is in the following format:
<your_plusnet_username>@plusdsl.net
<your_plusnet_password>
Ludo
Thank you very much Bob! We got there in the end...bigest problem was to find username as always been misspeled.
Fixes: 103
Glad to hear you're back online 🙂
