Job's a Good 'Un Plusnet.
k2150
My Plusnet broadband went active today, transferred from BT Infinity. I just wanted to say thanks, makes a refreshing change to call Plusnet Customer Services and speak to someone who's actually in the UK and not reading from a script, the call center staff have been great, as for my new Broadband connection, I've never had pings this low.  I'm really happy I made the move. cheers!
http://www.speedtest.net/my-result/3671478439
GeordieMark
Re: Job's a Good 'Un Plusnet.
Wow that is a very good ping! Grin
Acassim
Hi k2150,
Welcome to the community  Smiley
Thanks for taking the time to provide us with that feedback and thanks for you kind words. We're glad to hear everything went smoothly and it seems like you have a great connection!
goldenfibre
Fixes: 6
I wish I have that low ping!
Maybe BT put u on Speed – prioritise speed over stability for online gamers rather than Standard – best overall balance between speed and stability for general internet users.
BT FTTC had three modes:
   Stable – prioritise stability over speed for IPTV videoconferencing, home workers and businesses transferring data and IPTV.
   Speed – prioritise speed over stability for online gamers.
My ping is average range between 12ms and 9ms
k2150
I don't know much about the technical side, but my game servers are based in Holland, I'm getting pings of 15ms to holland so my gaming should get better
k2150
Quote from: Adam
Hi k2150,
cheers Adam
@ goldenfibre - I don't think being on a different BT Wholesale profile will make any difference with the ping times.
Out of interest, are you on a one of the new gateways (BNG)?
goldenfibre
Fixes: 6
U can check which gateway are you on: http://usertools.plus.net/@gateway
Mine is:
Which gateway
You are currently connected to gateway ptn-bng01.
This is located in Telehouse North.
I meant which gateway are you on.
I see higher ping times (3-5ms) on BNGs compared to the older gateways.
goldenfibre
Fixes: 6
Spot on AndyH some gateway seeing 25ms compare to other gateway 10ms.
I'll start a new thread on this.
goldenfibre
Fixes: 6
AndyH (the new gateway are more faster throughput speed than the older gateway) approx 1.5Mbps more! Very strange indeed.
k2150
gateway pcl-ag04.
