Jitter
- Jitter
Jitter
04-02-2013 6:01 PM
Just did a ping test, and can anyone explain jitter, in laymens terms?
Would wireless affect this at all? (test was done on wireless connection)
Cheers
Griff
Cheers
Griff
Message 1 of 3
(685 Views)
2 REPLIES 2
Re: Jitter
04-02-2013 7:31 PM
Jitter isn't really a term used much - it's something pingtest.net have put on their tests though.
I think it's the difference between the lowest/highest ping in the test. So the lower the number, the better.
Message 2 of 3
(364 Views)
Re: Jitter
04-02-2013 7:45 PM
If the ping was to the device rather than the router then the wireless may well affect the results, otherwise it wouldn't.
Message 3 of 3
(364 Views)
